cooling system question
Old Jan 18, 2012 | 07:38 AM
zarbatad's Avatar
Hi everyone... I'm new to Infinity and new to this board. I have a 2003 G35 and I seem to have a heater issue... it blows cold air at idle. When driving the heater blows nice and hot. The rad is full of coolant and the reservoir shows coolant at the Max level... any ideas as to why it blows cold air when idling... like when stopped at a red light?
thanks so much......
Dan
Old Jan 18, 2012 | 10:08 AM
TunerMax's Avatar
G35
Just based stricktly off past experience, this is normally caused by air in the system, or plugged heater core/hoses
Old Jan 18, 2012 | 12:57 PM
AARONHL's Avatar
You have air in your system. Look into bleeding it after you find the leak (if there is one). When the car is warmed up, the upper radiator hose near the reservoir should be solid and not collapsed.
Old Jan 18, 2012 | 03:32 PM
zarbatad's Avatar
thanks for the replies..... I'll look into bleeding it...
Old Jan 18, 2012 | 05:28 PM
TunerMax's Avatar
G35
1. Check for coolant leaks, if found, repair
2. Remove radiator cap and warm up to temperature, make sure overflow reservoir stays at the correct level. The air should purge out by itself with the cap removed.
3. Check for 'flow' in the reservoir with a flashlight down the cap spout when the engine gets hot, you DO want flow, but not excessive bubbling.
4. Inspect/test rad cap. You can bring it into any local shop they should be able to test it quite easy/quick on the cheap. You only have to bring the rad cap in unless you supsect a leak in the system.
Old Jan 18, 2012 | 05:45 PM
zarbatad's Avatar
excellent... thanks again!
Old Jan 19, 2012 | 08:36 AM
DARLLL's Avatar
This problem happenned to me when i first got my g... I later found out that the top part of the radiator( The plastic section) had a leak... Just take it to a radiator shop and have them check for leaks..
The plastic + labor was $120 for me...My heater has been working fine since then. Don't let any repair shop fool you to thinking its the heater core because that will cost a lot of money
Old Jan 19, 2012 | 07:49 PM
zarbatad's Avatar
good advice...... thanks Darlll
Old Jan 19, 2012 | 09:22 PM
AARONHL's Avatar
The bottom of my radiator has leaked before. Right where the metal is crimped onto the plastic.
Old Jan 22, 2012 | 10:33 AM
TunerMax's Avatar
G35
Originally Posted by iwantg35sedan
it's spelled infiniti
Enter Sir PW
Kng0fHrts
Sep 15, 2015 05:40 PM
Smittie20
Aug 9, 2015 04:29 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
