BC coilovers rear adjustment dilemma
#31
How big is the spacer? I asked BC and they said its about a 2 inch spacer. The spring would only help out with 3/4 of a inch? If anything you would need both to have the ability to change it from stock height and lower it to where you want it?
#32
I dont even know what is going on in this thread... some inexperience or something. I would be more than glad to take a pic of my car in its first year of winter mode, but my car has 3+ fingers in the front and around 3 in the back. This is from stock outside of tire to fender.
That is with the 210mm and no spacer. Someone is doing something wrong on your install. If i did a 3/4" longer spring or a spacer it would be higher than stock...
#34
Is that on your new wheels or stock wheels?
Would you be able to lower it without any issues? I'm trying to figure out if I should order the spacer, spring or both.
Currently I'm fine but my rears are both maxed out too. I wanted the ability to raise it higher for winter driving though. BC says if I got both and tired to lower it, I'd have to remove the spacer. I think the spacer is the soultion since it will offer the height I wanted but retain the ability to lower the car to where I want it. Adding the spring maybe overkill.
#35
#36
#37
#38
netcbc
Steering & Suspension CDN
07-24-2015 01:59 PM
netcbc
07-24-2015 11:25 AM
