My Struggles & Reviews with the Compression Rod Polyurethane Bushings
Old Feb 12, 2012 | 03:47 PM
Invalid_User's Avatar
Whiteline>energy CRB
Old Feb 14, 2012 | 01:57 PM
sgv_g35's Avatar
Originally Posted by DivZero
Was there a gap like in the ES bushings with the Armstrong ones?
Nope
Old Feb 14, 2012 | 04:19 PM
TOYSTA's Avatar
What kind of grease did you use for the ES bushings?
Old Feb 14, 2012 | 04:48 PM
sgv_g35's Avatar
The ES bushings come with white lithium grease
Old Mar 1, 2012 | 02:29 PM
Vegas4DR's Avatar
In for updates - i need to replace my bushings again. Last time I got a squeak. This time I'm getting a clunk. I was under my car trying to figure out WTF was loose. Found the compression rod to have way too much play. Inside part of bushing is torn.
Old Mar 1, 2012 | 05:55 PM
prinny's Avatar
The SPL bushings that you have are the old ones. If you email SPL they'll send you these O-rings that help to soften up or even get rid of entirely the creaking and knocking and etc. The downside is that you have to constantly keep them lubricated like with PB blaster once in awhile or something similar. Silicon spray on grease seems to last longer before you have to reapply. The benefits from the SPL bushings though are enormous. Well at least for me anyways. HUGE difference going from piece of crap OEM bushings to the SPLs.
Old Mar 2, 2012 | 10:54 AM
Vegas4DR's Avatar
I ordered the Whiteline Bushings. I have heard nothing but good things about them. I saw these guys at SEMA back in Oct as well. They explained and showed me all the good things.
Also, for those bushings that you bought (OP) - the ebay listing shows the direction of install.
Old Mar 10, 2012 | 07:57 AM
5150DS's Avatar
Update?
Old Mar 12, 2012 | 06:23 PM
Vegas4DR's Avatar
I haven't received my bushings yet, so i can't comment on whitelines so far.
I also would like to hear OP opinion of the bushings he's running since he's had them for a little while now
Old Dec 3, 2012 | 06:30 PM
firefox's Avatar
My whiteline bushings started to squeak. It sounded like a flap/squeak. I pulled them off this past weekend and there was a small tear in it (not sure if it affects performances. I installed the Armstrong bushing and used prothane grease.
Flapping went away but still was squeaking. Replaced my swaybar bushings on Sunday and squeak is now gone. Front suspension is all tidy now. Need to work on the rear this weekend.
Honestly, I think the prothane grease (19-1751) helps a lot in getting rid of the noises.
The SPL was a little too stiff for me, but it gave me the best performance on the corners. The Energy Suspension ones got noisy after a while, but can be helped with grease. Whitelines tore atfer 6 months, but it probably doesn't affect performance. The Armstrong bushings are nice in that they are one piece and the ends don't seem to separate from the rod itself under load (it drove me crazy on the energy suspension bushings, since water could get in there between the bushing and the metal.
Well see how they are after a few months of driving. If these don't last, I may go back to OEM.
Attached Thumbnails My Struggles & Reviews with the Compression Rod Polyurethane Bushings-wp_20121201_002-small-.jpg   My Struggles & Reviews with the Compression Rod Polyurethane Bushings-wp_20121201_001-small-.jpg
Old Dec 4, 2012 | 05:36 PM
sgv_g35's Avatar
Just checking in...its been 10 months since I've installed the Armstrong bushings. All is well so far with the bushings. Nothing to report (which is a good thing)
Old Dec 5, 2012 | 11:30 AM
MikeDG's Avatar
^That's encouraging to hear the Armstrong bushings are holding up well. My ES bushings have also torn, and by the looks of firefox's pics the Whiteline bushings don't appear to be any better. I'll be picking up a set of Armstrongs in the spring.
For those that have installed these, how hard are they to press into the compression rod? By the look of them the tapered top and bottom are larger than the inner bushing diameter. Since they are one peice, did you have any trouble pressing them through the compression rod?
Old Dec 5, 2012 | 12:23 PM
ohfive's Avatar
What are the prices for these Armstrong bushings? If you don't mind me asking.
Old Dec 5, 2012 | 12:37 PM
MikeDG's Avatar
For sale on ebay for $50.
http://www.ebay.com/itm/Infiniti-G35...item1e6ceb2e87
Old Dec 5, 2012 | 01:20 PM
  #30
sgv_g35's Avatar
Once I had the old bushing out of the arm, I put a little grease around the inside of the arm and the Armstrong bushing went through just fine.
