how to remove paint from tail lights?
Old Mar 7, 2012 | 09:29 PM
NjMatteSedan's Avatar
I got a fix it ticket today for my turn signals.being too dim. My tails are painted GTR style wirh reduced obsidian black paint and cleared. What option does my body guy have as far as paint removal?. Im only removing the paint in side the turn signal outline not on the whole tail light. Paint stripper is too harsh for the lenses, maybe gasoline? Some sort of wetsanding?
Old Mar 7, 2012 | 09:36 PM
JaE35's Avatar
Moderator
G35 Sedan
Stop by home depot and pick up a small can of goof-off and a roll of paper towels...wipes right off
Old Mar 7, 2012 | 09:57 PM
Idk if that would work with real car paint and clear tho what do you think? This isnt some thin vht niteshades paint. The tails are as dark and as glosdy as my quarter panels
Old Mar 7, 2012 | 10:18 PM
ryanm8's Avatar
You can definitely wet sand them if nothing else works. Then just clear and wet sand again, use rubbing compound and they'll look like new.
Old Mar 7, 2012 | 11:37 PM
dominate's Avatar
Is the paint painted over the parts that illuminate?
Old Mar 8, 2012 | 01:58 AM
r1forever80's Avatar
If its actual automotive paint they were shot with you only option to not mess up the lights will be to wet sand them. Tape off the area you dont want sanded and start with some 400 grit. Once you get thru the clear go up to 800 then finish off with 1000. untape and sand the rest of light with 1000 then have them reclear. They may have to do some spot shooting of the black though
Old Mar 8, 2012 | 07:51 AM
Yea the turn signal area is painted. Making the directionals really dim during the day
Thanks for the info. Sounds like it's gonna cost me a pretty penny to have em recleared and/if touched up
Old Mar 8, 2012 | 08:49 AM
DKano's Avatar
Did you try putting some bright LEDs on your turn signals instead of regular bulbs?
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
roboeclipse
Lights
Aug 13, 2015 10:45 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
