Sunroof barely works (help!)
Old Mar 8, 2012 | 05:36 PM
snowtrax's Avatar
Since today was very warm, I opened my sunroof. It opened very slowly but worked. I closed it and it was closing very slowly so I just went out and opened it to see if there were any obstructions in the tracks. It was all clean, no pine needles or dirt. I sprayed some lubricant and I went to shut it and it barely shut. I opened it once more to see if once the lubricant gets spread around it will work better. I go to close it and it closes slower and slower as it gets there. It stopped 3/4 of the way and rebounded and opened. I pressed the close button and pulled it along since it won't do it on its own and it was drizzling. It's almost like it has no power and now it's broken...ugh what a nice spring welcoming.
Old Mar 8, 2012 | 05:55 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
Sounds like your motor might be going out
Old Mar 11, 2012 | 12:01 PM
snowtrax's Avatar
I opened it and shut it with no problems today....I don't know what the problem is/was
Old Mar 13, 2012 | 08:59 AM
si_driver's Avatar
I have been having lots of small unexplained electrical problem lately with the car.
Maybe some short somewhere? or corrosion ?
Old Mar 13, 2012 | 09:27 AM
freakta's Avatar
A similar thing happened with my gtp. Get some good grease and put it on the tracks with a brush on both sides, front and back. Then run it back and forth. It really should fix the problem
derres
Aug 28, 2015 03:27 PM
chinee
Aug 8, 2015 10:11 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Frostbite91
Jul 27, 2015 05:25 AM
