How to maintain A G?
Old Mar 25, 2012 | 02:14 AM
  #31
bigjee's Avatar
Originally Posted by TunerMax
Well, the cold is a bit of a different situation, but not by much.
Below -15 Celcius (around 7 Farenheit), I'd for sure recommend letting hte engine warm for about a min or two. But that's pretty cold temps, and even this could be argued. More than a minute or two is not really necessary though.
Also, when running those temps you should be running 0w-30 oil, or somehwere there abouts, as such, the oil won't play into the discussion so much. Also, your oil pump turns in direct relation to engine speed. And the oil will flow better when you're not at idle, pretty much everything in the car works better when the car is under slight load and maintaining under 2-3k RPM revs until warm. Idling warms the car up slower, warms the oil slower, circulates the oil slower, etc, etc. So the longer you idle, the worse it is, period.
And any temps lower than that you should be using a block heater and/or electric blanket if you really give a crap about your car.
A few decent quotes that apply to this I've included below.
You'll note a lot of guys will recommend longer idle times in below freezing temps, this isn't really due to oil, but due to excessively cold block/piston, etc temps. The colder they are the longer they take to warm up to temp, and the colder they are the smaller they are, which means more wear on the engine, this is why you want to keep RPM down until the block has a minute or so to get to a reasonable tolerance.
Again though, more than a couple minutes is un-necessary and only more harmful, and this is ONLY in below-freezing temps. All other situations, just get in a drive slow until the car warms up
Pretty sure you're reducing the life of your engine if you're only warming it up for a miute or two at -15C.
I dont car what people say but at those temps you need to wait about 5min atleast and thats with a block heater installed.
Most drivers will instantly know the difference of when they put their car into R from P the first time on how much the engine and transmission has warmed up.
A warmer engine will shift into R or D more smoother.
this is my experience and I have nothing to prove for it.
But hey experience is a good teacher.
At those temps I usually let the RPM hit 1100 or 1000 before I move my car at all.
Old Mar 25, 2012 | 09:52 PM
  #32
TunerMax's Avatar
G35
Well, based on actual research, engineer's recommendations, etc, a minute or two is plenty, then as said, drive keeping rpm low until up to operating temp.
-15 Celcius isn't that cold, 1-2 minutes is a decent length of time for a car to sit there running at 1000 RPM.
Experience is useful, and has a place, but it's actually a horrible teacher
Old Mar 25, 2012 | 10:26 PM
  #33
herrschaft's Avatar
but idling for long is harder on the environment.
Old Mar 25, 2012 | 11:02 PM
  #34
AARONHL's Avatar
Stay off the curbs, I've learned my lesson too late
Old Mar 26, 2012 | 08:36 AM
  #35
snowtrax's Avatar
I swear I just made a thread explaining all of the maintenance items.
Old Mar 26, 2012 | 10:09 PM
  #36
TunerMax's Avatar
G35
And next week, another one will rise
seagrasser
May 3, 2022 09:43 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
infinitiway
Aug 8, 2017 12:38 PM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
MrIP35
Oct 25, 2015 11:13 PM
