Question about coupe seats in 03 sedan
Old Mar 27, 2012 | 01:43 PM
midnytegsedan's Avatar
Now I've gone through all the threads about swapping the coupe seats into the sedan and the drivers side is pretty simple for the most part but my 03 sedan didn't come with a power passenger seat. It was just the regular run of the mill bar that you pull up and the seat slides back and fourth. When I install the passenger coupe seat (which is obviously power) am I going to run into any issues with this? Any info would help, I plan on doing this today so i guess for the mean time I will start on the drivers side. Thanks guys
Old Mar 27, 2012 | 01:49 PM
azazell64's Avatar
https://g35driver.com/forums/g35-sed...ring-info.html should get a start on some info on how to do them, if not I would PM him.
Old Mar 27, 2012 | 04:51 PM
/\ thanks that helped out alot the seat is installed and works fine only thing is the air bag light in flashing on and off now
Old Mar 27, 2012 | 05:11 PM
G35Papa's Avatar
It's been a while since I put mine in and I can't quite remember but I think there is a airbag plug up behind toward the outside of the seat if you follow the harness wires. Are you sure everything was plugged in? The harness/plugs that are yellow are for the airbags.
Old Mar 27, 2012 | 06:31 PM
Yea i saw the yellow plug and they were connected fine. I followed the wire as far back i could and i didn't see anything else attached. I will get back under there in a day or so when i install the pass side. Thanks though
Old Mar 27, 2012 | 07:08 PM
ray1370's Avatar
Did you turn the power on during the installation by any chance? If you turned it on while the air bag is disconnected, the light will flash even after you connect it back. Do the reset first, if it doesn't fix it then the air bag might be faulty.
Old Mar 27, 2012 | 07:20 PM
G35Papa's Avatar
No problem. Good luck
Old Mar 27, 2012 | 10:53 PM
How do you do the reset?
Old Mar 28, 2012 | 01:43 AM
ray1370's Avatar
Just do a search using keyword "airbag reset" and the DIY thread should be within the top 5 results.
R350k5
Oct 1, 2015 08:41 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
brian_z
Jul 20, 2015 01:30 AM
mushu
Jul 15, 2015 03:55 PM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
