alignment question
Tuner Max, it is in spec doug LOL
Caster cannot be adjusted
Toe is fine, 0.00 would be perfect, but one pot hole could potential change that
Camber at -1.5 is fine too, probably won't notice any premature tire wear
If the car is driving straight without any drifting or pulling I wouldn't go back.
If I want it set up so it 'feels ok' and drives fine, then I'd do it myself in the driveway, I wouldn't pay someone to do it 'properly'.
Clearly, the shop didn't do a professional job.
I agree with you though, the numbers aren't way out by any stretch of the imagination, and he'll be fine to just run it like that without real notable adverse effects. But is it in spec? Is 'it'll be fine' the answer you want when you lay your hard earned dollars down?
It's only my opinion, OP, you'll be fine with either decision. I'm just picky, and if they'll re-do it for free as you say, then I think it'd be silly NOT to take it back.
rezendvous420
05-31-2020 01:26 PM
