Rotor and Brake Pad DIY
Old Apr 6, 2012 | 08:26 PM
Simm0nS777's Avatar
Is there a DIY video to swap out the rotors and brake pads on a 06 G35X? How difficult is this for a beginner to do? I have all the parts (rotors and brake pads) and am trying to save some money on the labor if I can and would also just like to learn.
Thanks!
edit: I did check the DIY sticky and didnt see one in there
Old Apr 6, 2012 | 09:36 PM
al_macaroni's Avatar
There is a video out there. Check on Google and YouTube.
Generally, the most difficult part on the brake job is breaking loose the old rotor. One tip, you can use an M8 bolt to "pop loose" the front rotor. You will see a threaded hole on the rotor. Just tighten the bolt into the hole.
The rear does not have a similar hole, but you can use a 5/16 bolt through the caliper bracket to "pop off" the rear rotor. This is much easier than beating them loose with a hammer.
Keep one lug nut on while you are breaking the rotor free
Good luck
Old Apr 6, 2012 | 10:22 PM
5150DS's Avatar
It isn't that hard, but to he safe; what experience do you have working on a car?
Old Apr 7, 2012 | 07:20 AM
Jairen's Avatar
http://infinitihelp.com/diy/gcoupe/b...sion_tires.htm
Old Apr 7, 2012 | 10:21 AM
01yellowr's Avatar
If this is your first time working on cars I don't think a brake job is the best option. If you have a person more familiar with doing that you may want to ask them to help you the first time just to be safe
Old Apr 7, 2012 | 09:14 PM
hyperwhite's Avatar
What 01yellowr said
Jon81035
Sep 16, 2015 04:58 PM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
3000vr4tt
Sep 7, 2015 12:48 AM
Machine Head
Sep 4, 2015 07:22 PM
