Absolutely no electrical power
Old May 14, 2012 | 07:59 PM
jzanone's Avatar
I went out to start my car this afternoon. The door unlocked okay with the remote. When I put the key in the ignition there was no power whatsoever. Everything is completely dead. No thing that needs electrical works. Remote does not activate anything at all. Has anyone experienced this? I can only think that a fusible link blew at the battery and completely disconnected everything. Any other ideas? Thanks for the help.
Old May 14, 2012 | 09:17 PM
AARONHL's Avatar
Did you check battery voltage (at the battery)??
Old May 14, 2012 | 09:22 PM
marteb73's Avatar
does anything else work (outside of through the ignition) like hazards, lights, etc. ?
Old May 14, 2012 | 10:21 PM
jzanone's Avatar
I had to leave to get a ride home so I did not get a chance to check anything at the battery. However, there is no power anywhere, not even a hint of power. No interior lights when the door is opened, nothing when the key is put in the ignition, nothing at all when using the remote. The battery itself is only about 6 months old and everything was working perfectly when I had parked it at work only 8 hours earlier. And no, the lights weren't left on.
Old May 14, 2012 | 10:35 PM
AARONHL's Avatar
Maybe one of the battery connections loosened??
Old May 15, 2012 | 01:36 AM
RADRaze2KX's Avatar
true story... happened to me once
Old May 15, 2012 | 06:58 PM
marteb73's Avatar
loose battery cable has been an issue for me in the past as well. def worth step one check..
Old May 15, 2012 | 07:17 PM
jzanone's Avatar
Thank you all. It was the battery cable. Apparently it worked itself loose as the terminals on the new battery must be thinner than the old battery. The clamp required some modification to make it a little tighter.
Old May 15, 2012 | 07:44 PM
nghiars's Avatar
^^^it happens to the best of us. Good thing its a "cheap" fix!!!
Old Oct 25, 2019 | 03:19 PM
Tanner Forcum's Avatar
g37 sport sedan
same exact thing just happened to me! This is the simplest fix but saved my *** thank you!
Freeman186
Sep 6, 2023 10:07 AM
Danielek
May 1, 2022 01:28 PM
