best fluids and oils to use
Old May 20, 2012 | 06:20 PM
05BlkGSedan's Avatar
i have a black 05 sedan.
and there is some maintenance due and id like to do as much of it by myself as possible.
and i was just wondering what oil and fluids you guys reccomend.
main ones i need now are engine, tranny and diff.
i have a bunch of friends reccomending royal purple or lucas oil.
also since i got it in 2010 my windshield washers havent worked. I checked all the fuses and they are good. ive disconected the hoses at the wiper and blew in it and you can hear bubbles in the resivoir. but i think my pump may be bad? i filled it up shortly after i got it and its litterally still overflowing when you take off the cap, 2 years later. ive put needles and what not in the sprayers themselves there was some calcium but i just cleaned it with clr. do i need a new pump?
Old May 20, 2012 | 06:50 PM
snowtrax's Avatar
Use only Nissan fluids. You can get them at the dealer or on eBay for about the same price.
Old May 20, 2012 | 07:14 PM
prinny's Avatar
For engine oil just use Castrol Syntec 5W30 and call it a day. There are way too many threads on what's the best oil to use and etc etc. Royal Purple is a waste of $$ btw.
Tranny you're going to need to get it from the dealership and it won't come cheap, but it's the only thing that will work. Should be around $15 a quart unless you can get it a different way or you know people.
Diff you have more choices.. 75W-90 or 80W-90. Mobil1 synthetic is cheaper usually and it works fine. That's what I'm replacing mine with soon when I get my car back.
Not sure about the wipers though.
Old May 20, 2012 | 07:17 PM
dofu's Avatar
20 Year Member
Motul
Old May 20, 2012 | 09:17 PM
5150DS's Avatar
For the trans you can use Castrol import multi vehicle trans fluid; no need to use the Nissan Matic J or S, unless you are under warranty. For oil, use Penzoil, Castrol or Mobil 1 synthetic. For rear diff, use one of the major oil manufacturers 75W90 synthetic.
I wouldn't use Royal Purple since it is cost prohibitive. If I was going to use a premium oil, I would use Amsoil.
Old May 20, 2012 | 09:23 PM
MeNmyG35's Avatar
I use all oem parts except for this afternoon starter went it's up n running now
Old May 21, 2012 | 08:17 PM
infinitig35's Avatar
In my car: for oil I use Mobil1 full synthetic, the other fluids are factory.
Old May 23, 2012 | 08:27 PM
Viroshan's Avatar
On my car, I used redline synthetic oils for the tranny and rear diff.. For engine I use ENEOS 5W-30 paired with a K&N oil filter.. Felt a huge difference, highly reccomend it!
Old May 24, 2012 | 12:19 PM
bigjee's Avatar
German castrol 0w-30 especially for the weather here.
Matic J for tranny and K and N oil filters (Mobil 1 and Bosch ones are pretty good too).
seagrasser
May 3, 2022 09:43 AM
g.spot
May 9, 2016 10:54 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
MrIP35
Oct 25, 2015 11:13 PM
DRG35R
Sep 16, 2015 05:33 AM
