Having some trouble with clear corners..
Old Jun 20, 2012 | 07:55 PM
dominate's Avatar
I bought the jdm clear corners (bump) and am trying to install them. I popped the old corner just fine, and was able to remove the corner from the stock bulb. However I am having a hard time removing the stock bulb itself from the harness or whatever you want to call it to install the amber bulb that came with the jdm corners. Any tips? Do clear corners look better with the stock or amber bulbs? Do I just use force or is there some trick to it? Thanks
Old Jun 21, 2012 | 05:02 AM
Blue Dream's Avatar
I drove ttrank's car solo
IIRC you have to push down a little and twist the bulbs to get them out. If they're tight, use a towel so if they break you don't gash yourself.
Old Jun 21, 2012 | 06:35 AM
ArkansasG35COUPE's Avatar
I used a little contact tuner cleaner from work to get mine out... After 4 years in and some road grime, they tend to stick in there pretty well. Blue Dream is right, a paper towel will help. The amber looks better IMO, but you should go LED to really make them pop!
Old Jun 21, 2012 | 06:36 AM
dominate's Avatar
Thanks guys for the input, I had actually got out not too long after my post. Somehow ended up with a bleeding cut under my skin though lol =\
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
dseet
Oct 11, 2015 12:40 AM
