Question about rims/tires.
Old Jun 28, 2012 | 12:05 PM
Dr3w5ki's Avatar
I have an 03 sedan with 275/35's on the rear and 245/35's on the front... When I had my car lowered an inch and a half in the rear, the fender literally sit on the tire and rubbed some tread off. I'm just wondering how people lower their cars to where the fender is on the tire and it doesn't affect anything... Is that rolled fenders? Stretched tires? Any help would be appreciated.
Old Jun 28, 2012 | 12:13 PM
04nismoG's Avatar
You will have to get the rear fenders rolled
Old Jun 28, 2012 | 12:16 PM
Dr3w5ki's Avatar
Rolled or flared? And then I can drop it back down?
Old Jun 28, 2012 | 12:17 PM
04nismoG's Avatar
just rolled should be ok
Old Jun 28, 2012 | 12:36 PM
Songle6MT's Avatar
What is the offset of your wheel?
Just rolling the fender usually does the trick. People that need to pull/flare fenders are usually running pretty intense offsets.
So many different factors play on how a wheel fits in the wheel well. Including what you have listed ( Fender work, Tire stretch ) but also on, how wide the wheel is, what the offset of the wheel is, and what your camber is at.
Old Jun 28, 2012 | 01:04 PM
Dr3w5ki's Avatar
Honestly, I don't know the offset of the wheels. I bought them used, and the guy never told me. They're 19x9 front and 19x9.5 rear.
Old Jun 28, 2012 | 01:57 PM
broke_as_ajoke's Avatar
Yea, depending on the offset.. one u can do that should fix the problem is have your fenders in the rear rolled.. Also, some of the guys run negative camber with stretched tires in the rear.
Old Jun 28, 2012 | 02:05 PM
Dr3w5ki's Avatar
I'm getting my fenders rolled Sunday, and according to what y'all are saying, hopefully it'll work.
Old Jun 28, 2012 | 02:25 PM
G35xTurbo's Avatar
Yeah, rolling the fenders and/or running stretched tires should fix it. I'm curious what the offset is on your wheels too. Pics?
Old Jun 28, 2012 | 02:35 PM
Peoria35sedan's Avatar
If the outside edge of the fender sits on the tire rolling the fenders not going to make a difference, on top of that if it's not done correctly you risk damaging the paint. You should check into adding negative camber to tuck the tires first, no sense in effing up you car just to find out you've got the wrong wheels.
Old Jun 28, 2012 | 02:50 PM
Dr3w5ki's Avatar
Yeah, the outside of the fender is sitting on the tire. How do I add negative camber and/or stretch tires? Sorry, I'm new at all this stance stuff.
Old Jun 28, 2012 | 02:51 PM
Dr3w5ki's Avatar
G35xturbo: I'm on my iphone, I don't know how to add pics from here.
Old Jun 28, 2012 | 03:11 PM
Dr3w5ki's Avatar
That's with the 255's on the rears, I'm about to upload one with the 275's.
Old Jun 28, 2012 | 03:15 PM
Rear camber adjusters to gain negative camber, but the inside of the tires wear out. Search this site, there are a ton of posts covering this.
Stretched is a narrow tire on a wide wheel, check out this thread
https://g35driver.com/forums/media-s...tch-sedan.html
Old Jun 28, 2012 | 03:16 PM
Dr3w5ki's Avatar
