Camber arm Nut spinning!!! HELP
Old Jul 6, 2012 | 03:46 PM
SuperTrooper699's Avatar
My coils came in today, i'm in the process of installing them, of course after taking out the strut and throwing the coils on, i decided to put on my aftermarket camber arm. the nut to take the camber arm off is spinning. I've tried several different ways to break it loose but i cannot. Has anyone had this problem and came up with a solution? Please post ASAP!
Old Jul 6, 2012 | 11:59 PM
Theory_EK's Avatar
Are you talking about the castle nut?
Old Jul 7, 2012 | 12:17 AM
herrschaft's Avatar
Which camber arms?
Old Jul 7, 2012 | 02:21 AM
AARONHL's Avatar
Try C clamping the arm to the spindle and turning the nut
Old Jul 7, 2012 | 08:50 AM
redpearl99's Avatar
if you are taking about the castle nut connecting the front a-arm then you need to place pressure on the suspension or the nut will continue to spin
Old Jul 7, 2012 | 11:50 AM
I'm not sure man its the nut that has the cotter pin in it. i took it out and it free spins now! got my coils installed then ripped them back out because of that!
Old Jul 7, 2012 | 02:39 PM
TunerMax's Avatar
G35
LMFAO
If you want more help specify location on the vechicle, there's front and rear camber arms for this car, and there's more than one nut/mount for all of them.
Old Jul 7, 2012 | 02:51 PM
redpearl99's Avatar
if it's the one with the cotter pin then it's the front a-arms. As I said, you need to apply pressure on the suspension when taking off the nut or it will spin freely
Old Jul 7, 2012 | 03:00 PM
neo_anderson302's Avatar
Why dont you post a pic, How hard is that?
Old Jul 7, 2012 | 07:50 PM
TunerMax's Avatar
G35
This^^^^^^^^
Just grab a set of Adjustable pliers or a c clamp or whatever and pinch the knucle to the upper control arm to put tension on it.
This is the easy part (getting it off)
Then you need a 2 jaw puller to remove the cone piece. If you don't have that you'll need to take the control arm to a shop to remove the cone.
Old Jul 8, 2012 | 02:36 PM
Thats the nut FRONT CAMBER ARM, i tried putting pressure on the suspension and a C clamp on the control arm, the nut still free spins the same.
[IMG][/IMG]
Old Jul 9, 2012 | 08:29 AM
pulsar1's Avatar
If you are putting adjustable arms on just cut it off.
Old Jul 9, 2012 | 08:46 AM
TunerMax's Avatar
G35
Take a solid punch or something flat and put it up against the 'flat' of the nut, and give it a good smack with a hammer, repeat this for all 6 'flats' on the nut.
Then get that tension on there TIGHT with the pliers/clamp, you'll probably need a buddy for this.
Also, Air impact might be reqired. But you can try it by hand with above method first.
And if that all fails and you cant get an impact, do as pulsar 1 said, just be VERY CAREFUL, do NOT touch the aluminum. I'd recommend against cutting it but as a last result you CAN do that.
The thing that is spinning isn't actually the nut, it's the whole shaft, as well as the tapered cone that is inside the knuckle. You're trying to put a bunch of pressure on the tapered cone so that it can't spin anymore, once you do that properly that nut will crack free.
Old Jul 11, 2012 | 03:04 PM
AARONHL's Avatar
Jack up the spindle on the lower ball joint to compress suspension and then use the C-clamp:
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
jilljann1
Jul 21, 2020 08:12 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
