Engine swap 04 g35x
Old Jul 31, 2012 | 06:02 PM
TunerMax's Avatar
G35
Originally Posted by JaE35
Really? I could've sworn the engines are the exact same
Revup vs. non revup? no. But you know that
Old Jul 31, 2012 | 06:16 PM
JaE35's Avatar
Moderator
G35 Sedan
No, talking autos not manuals
Old Jul 31, 2012 | 08:25 PM
TunerMax's Avatar
G35
Pffffft Auto's don't count.
Old Jul 31, 2012 | 08:33 PM
JaE35's Avatar
Moderator
G35 Sedan
Old May 6, 2013 | 10:24 AM
vee35's Avatar
My mechanic recently did the swap from my 04 x auto engine to a 05 6mt engine but runs and drive smooth but the service engine lights is on. Any clue?
Old May 6, 2013 | 01:24 PM
TunerMax's Avatar
G35
I have a radical idea for you but I doubt it will help.
CHECK WHAT CODE IT"S THROWING
Old May 8, 2013 | 11:24 AM
onevoice's Avatar
Wasn't an '05 manual a REVUP engine? How did he manage to do the swap?
But yes best would be to take trip to the nearest autozone and get a free code reading.
Old May 8, 2013 | 12:10 PM
tqstarburst's Avatar
I don't know if this helps but, my g35 sedan (05 6mt) threw a rod, made a hole in the block( a big one) So I replaced the engine. I originally bought the engine from a dude whom said it came off an 05 g35 coupe so I was like ill take it. Turns out the engine was from an 04 coupe 6mt. So what we did, we just changed the heads from my 05 to the 04 engine. Obviously we took the head,engine to the machine shop etc. I retained my original pieces, wiring, ecu and so on. Works perfectly fine with no issues.
So basically i got the block off an 04 coupe 6mt engine, swapped heads form my 05 6mt rev up and is working fine. I heard to change the oil pump from my 05 to the 04 engine as this would work better with it? Anyone know anything about this?
Old Jun 17, 2013 | 12:17 PM
Chucks 04's Avatar
Has anyone here built a VQ35de all motor and if so what was the out come?? I'm thinking about doing that.
Old Oct 5, 2020 | 10:51 PM
Tim Sterling's Avatar
g35x
Originally Posted by ccc123pm
04-06 awd sedans are the same. RWD went to the revup motor for 05-06, but AWD did not.
is this true?? any other references? lol
Old Oct 6, 2020 | 10:22 AM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Thread revival much?
All '03 - 06 (+ '07 Coupe) cars with the 5AT (including 04-06 G35x) are the standard DE
'All 05 - 06 (+ '07 Coupe) 6MT cars are RevUp DE (The RevUp was ONLY with 6MT cars)
2007+ Sedans are the HR (and later VHR)
2008+ Coupes are VHR
Jiggerjuice
Oct 5, 2015 02:33 PM
Gookiecrunch
Aug 19, 2015 12:00 PM
chinee
Aug 8, 2015 10:11 AM
joedaddy1
Jul 28, 2015 02:58 PM
