New G-Driver. Old G35...
Old Sep 4, 2012 | 02:01 PM
  #31
SpankinHamz's Avatar
Finally got her back over the weekend! Looks awesome.. Imma put the wheels on later today or tomorrow. Cant wait to see how those staggered 20s are gonna look. My only complaint is the rubber trim at the bottom of both front doors need to be replaced.
Old Sep 4, 2012 | 02:44 PM
  #32
04nismoG's Avatar
Eagle one makes a trim shine you can use for that discolored trim along the bottom of the car. I use it and the car looks pretty much new.
Old Sep 4, 2012 | 03:10 PM
  #33
X-Rated's Avatar
im reporting you for robbery lol haha stole that car! good luck with fixing it up, looking like you shouldnt have too much problems restoring it. the faster u restore the faster you get to modding! so welcome and good luck ! cant wait for the end product
Old Sep 4, 2012 | 03:23 PM
  #34
SkyWay's Avatar
Need to polish those headlights and use some back to black on the lower unpainted sills
Old Sep 5, 2012 | 05:42 AM
  #35
prinny's Avatar
Originally Posted by gq916
the stock intake is already pretty good...i would just do a drop in k&n filter..dont waste your money on a z tube..stock piping is fine. I had a z tube for a long time..sold it last year and put my stock pipe back on.
huh? The stock one sucks. There's alot more restriction.
oh.. and for the horrible black rubber trim.. click on this.. http://www.leatherique.com/products.html then find LEATHERIQUE RUBBER BLACK DYE. It actually dyes the rubber and works a hell of a lot better and lasts way way longer than any of those other products.
And oh invest in a bodykit
Old Sep 5, 2012 | 12:12 PM
  #36
Thanks for the tisp on renewing the rocker trim. Im actually talking about replacing that tiny rubber seal hanging from the bottom of the front door tho. Just above the rocker trim....
Ill be installing the rims today so I can measure wheel gap. Hopefully Ill have time afterword so I can place an order for spring, ball joints and a plenum spacer tonight. If Im not rippin the town.. As far as intake. Ill start with just a K and N drop in filter when I replace oil and plugs over the weekend. But Ill watch ebay for a Ztube!..
Any suggestion on things I should or shouldnt do to my G are welcome
Old Sep 5, 2012 | 01:42 PM
  #37
This part here..
Old Sep 5, 2012 | 01:45 PM
  #38
SkyWay's Avatar
Don't put 20's on the g lol
Old Sep 5, 2012 | 04:50 PM
  #39
Too late.. I bought a set while the car was in paint.. 3" front lip and 4.5" rear lip
Old Sep 6, 2012 | 01:34 PM
  #40
65chev's Avatar
Use a wet soft cloth with tooth paste, polish the head lights and they will come out looking great. Before you buy those headlight repair kits, its costs nothing to try. I did my wifes car and she was happy.
BTW nice car.
Old Sep 15, 2012 | 03:33 PM
  #41
Sorry It took so long to get back here.. Just been riding the town getting a feel for whats to come.. The fronts fit lovely with an inch room to drop. But the rears are .5 inch too wide and poke out a bit. Thinking maybe camber+rolling and pulling the rear fenders will get her hella flush after a set of Z springs... What you guys think?
Old Sep 15, 2012 | 08:40 PM
  #42
onlyme732's Avatar
I have a 2003 G35 for 9 years. Still runs good, now about 213K miles. Question - Do I need to change the spark plug coils? Never change the coil before. The s/plugs were changed according to prescribed maintenance schedule. Your input appreciated. Thanks.
Old Oct 2, 2012 | 02:05 PM
  #43
If they still work I wouldnt! From what I understand about coil packs is. They either work or dont..
Old Oct 2, 2012 | 02:24 PM
  #44
Update!
I havent stopped working on the G! Just got a new Red clicker and programmed it plus wired up my phone to bypass the factory radio.https://g35driver.com/forums/audio-v...layin-now.html
Replaced all for shocks with set of Sensen I got off ebay for 130 buck and cut a coil out of the front to give the G an even stance. 2 fingers front and back
BEFORE.. check the frontal lift! Oh and my Icy a$$ 460! Both dirt cause I actually USE em.
AFTER
Front
Rear
Ive gotta do the brakes next. Thinking about drilled rotors all around for a sik *** look!
Old Oct 2, 2012 | 04:11 PM
  #45
Peoria35sedan's Avatar
Originally Posted by SpankinHamz
Dude! That the fithiest interior I've ever seen, clean that s**t up.
I'd stick with sock rotors, your brakes must look tiny inside those wheels.
