What oil filters do you guys use?
Old Aug 12, 2012 | 05:23 PM
thescreensavers's Avatar
Mr.202?
Originally Posted by Herbbie Hablib
Even the Made in Japan ones?
Are they different from this one? LINK
Old Aug 13, 2012 | 11:39 AM
albundy1987's Avatar
Speaking of oil filters, anyone done an oil filter relocation? I'm thinking about the GTM, but they don't sell a kit. I would have to piece it together. Search turned up nothing useful.
Thanks in advance.
Old Aug 13, 2012 | 12:16 PM
Mr. Brett's Avatar
Why?
Unless you're planning on doing some serious modding to your motor, why would you relocate it...?
The oil filter on these cars is actually in a fairly easy to reach place.
Old Aug 13, 2012 | 05:41 PM
Because I can't leave anything alone. Also, for whatever reason the aluminum under tray that I bought won't let me get the filter out through the access panel. I have 2006 G35x and the sway bar is all kinds of in the way.
Old Aug 13, 2012 | 10:42 PM
lox1985's Avatar
Where is the best/cheapest place to get these?
Old Aug 13, 2012 | 11:08 PM
jj115's Avatar
Mobile 1
Old Aug 13, 2012 | 11:09 PM
AuAltima3.5's Avatar
Oem
Old Aug 14, 2012 | 03:03 AM
gq916's Avatar
all oil filters are ok...never been a fan of fram tho..i used k&n for a long time..now using PureOne...you can buy them off amazon for $5 and its easy to grip
Old Aug 14, 2012 | 03:39 AM
5150DS's Avatar
Originally Posted by AuAltima3.5
Oem
Own has same cheap construction as fram and as such is over priced.
Old Aug 14, 2012 | 08:46 AM
superman22x's Avatar
I wouldn't do it unless you really have to. It ends up causing issues more often than not, and don't go cheap. Cheap kits leak.
Old Aug 14, 2012 | 01:37 PM
Mustang5L5's Avatar
Purolator Pure 1 here.
SOmetimes the parts store sells the 5-quart bottles cheaper with a fram filter (under $4.99) so i just grab a random fram and get a few bucks off.
When i get 5-7 of the fram filters i toss them on Ebay for $10 or so and get some cash back.
Old Aug 17, 2012 | 03:31 PM
TheTick's Avatar
I use the oem Maxima filter because it's larger. Religiously change oil myself every 10K miles with mobile1 topping off when necessary. I'm now at 180K miles and motor runs like new. Other than changing belts and plugs, not a single issue yet.
Old Aug 17, 2012 | 03:52 PM
Mr. Brett's Avatar
I don't care what a motor oil is rated for. I would never go over 5,000 miles, even with full synthetic. Glad to hear your car is doing fine, though...
I used to run Mobil1 in my Maxima due to oil consumption issues. I would run it to 5k.
Old Aug 17, 2012 | 04:02 PM
SuperTrooper699's Avatar
I use the pure-one Q45 Filter its a bit bigger than the G35 filter.
Old Aug 17, 2012 | 04:31 PM
  #30
HenryLee's Avatar
^ Exactly what I do... and I use Pennzoil Ultra now..
