Weakening wiper arm
Old Aug 13, 2012 | 07:06 PM
sakage.shinga's Avatar
Weakening wiper arm
Hi guys,
For a few years now, whenever the driver's side wiper comes back down after its upward stroke, it would leave behind a massive puddle of water that blocks my view. I've tried changing wiper blades and cleaning the windshield, both of which will temporarily & superficially alleviate the problem, but never fix it long term.
The other day I took the car to my local windshield shop and the tech guy said that the driver's side wiper blade is basically "hydroplaning" when it's in the downward stroke, and that that is happening because my wiper arm (not the blade itself) is weakening.
He then suggests that I 1) apply aquapel, and 2) get the Motomaster Precise-Fit wiper blades.
My question: has anyone used Motomaster Precise-Fit? It's supposed to provide more pressing-down pressure than traditional blades. Also, is there any way of tightening that wiper arm?
Thanks!
Old Aug 13, 2012 | 07:55 PM
dofu's Avatar
20 Year Member
Bosch ICON
or Valeo Ultimate.
A little Rain X helps too. You'll be alright using Rain X as long as you're using silicone wiper blades.
Old Aug 18, 2012 | 09:17 PM
Thanks for the reply.
I currently have Rain-X beam blades (not sure which model) installed and at first they did help quite a bit, but the effect has gradually disappeared. Getting quality wipers (or anything tech or auto-related) in Vancouver, BC is a major headache. We get sub-par products at the same, if not slightly inflated, prices compared to people south of the border...sigh...
I'll try to hunt down the Bosch Icons you recommended.
Old Aug 23, 2012 | 08:14 PM
dofu's Avatar
20 Year Member
Tirerack.com has a few good wipers you can order online.
Old Aug 24, 2012 | 11:05 AM
GGGVenom's Avatar
It sounds like your wiper arm may need replacement (spring on arm sounds worn) and replacing wiper blades is a very short term fix.
Old Nov 18, 2013 | 01:12 PM
ChrisWilley's Avatar
INFINITI G35 Coupe
Has anyone been able to find a wiper arm spring replacement part number? Buying the whole arm seems a little ridiculous.
Old Nov 18, 2013 | 03:34 PM
Mustang5L5's Avatar
If the wiper arm is weak, why try a band-aid solution?
Have you inspected the arm? There are springs which give the arm is't tension. I've never heard of them weakening however. Damage is a possibility though.
I'm not sure I beleive the tech's diagnosis. For that to happen, the wiper would have to travel at a high speed, and it would require quite a bit of water to be on the windshield. I would be cautious and do my own investigating.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
