Worked fine for the first 20 minutes shut the car off hour later went out and now the car wants to stall and the rpms jump up n down. What's wrong???
Quote:
There's two lines to connect right? I'll have to check the one hooked up on the ztube. Maybe I didn't put it on right.Originally Posted by shane11
you forgot a vacum line.
Shanes_G
close
- Join DateAug 2011
- Locationvirginia beach
iTrader Positive Feedback100
iTrader Feedback Score(22)
Liked:820 Times in 595 Posts
yea check that,bc i did the same thing and dident know what it was for a while.
Quote:
Thanks.Originally Posted by shane11
Now its raining won't be able to fix this until tomorrow. I checked the connector by the air box. Was fine. So tomorrow I'll take the intake tube off n check out the connection there. I hate how they put it under the tube. So that would be the only thing causing it? Weird it ran great shut the car off the hour later I got problems.
saywat?
close
- Join DateApr 2009
iTrader Feedback Score(5)
Liked:484 Times in 430 Posts
sometimes the end thats attach to the engine comes off when ur moving the line around to attach it to the tube
Quote:
Never thought of that. ThanksOriginally Posted by saywat?
Wow!!! Now I need my car towed! Can't be the intake. Everything is connected right. I can't even push the gas pedal. Car wants to stall.. this is crazy. Friend thinks its the throttle wire.
It's been a few days now, did you ever figure it out?
I would just put everything back to how it was and see that helps. Maybe the MAF was damaged somehow. Or you have it installed backwards.
Dirt in MAF.Originally Posted by petro2342
It's been a few days now, did you ever figure it out?I would just put everything back to how it was and see that helps. Maybe the MAF was damaged somehow. Or you have it installed backwards.
