Newbie here. Need advice
Old Dec 7, 2012 | 06:02 PM
  #76
06G35Coupe94's Avatar
Originally Posted by saywat?
i could see an independent shop owner doing stuff like this but at a dealer i dont see why they would mess with peoples cars to get more money from repairs cus the tech aint gonna see a dime from it aside from his usual salary. but would they over exaggerate an issue?..possibly but they usually over estimate an issue cus they want to fix every little thing imo lol
Well its out there. Like recently a guy who took his camaro to the dealership, they beat it to hell. They ended up burning the clutch and charged the guy for a new one. It was on the news
Old Dec 7, 2012 | 06:17 PM
  #77
Eno's Avatar
Eno
I got lucky in that one of our local forums named one particular dealership that had a service manager who was undoubtedly "one of the good ones." It was a no brainer to take the car there to get work done properly, promptly and professionally. They raved about this guy. I had to get some minor work done and he did not disappoint. He also took some interest in the car- and he had an appreciation for the modded platform.
Though nightmare stealerships certainly exist (like the dealer 1 city over 20 minutes away) you can definitely minimize your drama by turning to your local enthusiast forum or even this broader Driver community!
We have a vendor feedback section. Sometimes I wonder if the regional section should have a dealership feedback section.
Old Dec 7, 2012 | 06:41 PM
  #78
VMRWheels's Avatar
Honestly I think it's probably coincidence but there is definitely the possibility.
Old Dec 7, 2012 | 08:28 PM
  #79
saywat?'s Avatar
i can imagine an angry or irritated tech doing something like this tho lol
Old Dec 7, 2012 | 11:14 PM
  #80
Ultraslan-ny's Avatar
Quick Autozone Question
I just bought 5 qts of GC + Bosch filter for $34.
The deal ends in 2 days.
Is this really a good price so i can buy some and use them later.
Or do they have similar deals on Castrol all the time? No need to hurry?
I am not familiar with their deals.
Old Dec 7, 2012 | 11:33 PM
  #81
mikhaelbt189's Avatar
it is a good deal.. the price each without deal i believe 8 dollars times 5=40. no filter included yet.
Old Dec 7, 2012 | 11:40 PM
  #82
w4kj4k's Avatar
when you say GC, are you talking about the German Castrol?
Old Dec 7, 2012 | 11:57 PM
  #83
joedaddy1's Avatar
ehhhhh.. they do castrol every 3 months or so..
Old Dec 8, 2012 | 12:01 AM
  #84
Yes sir.
Thats the answer that i was looking for. I will barely make 5k in 3 months... So its all good then.
Old Dec 8, 2012 | 12:57 AM
  #85
TunerMax's Avatar
G35
Originally Posted by Ultraslan-ny
Couple days ago, I opened the door and put the key on ignition but the car lost power completely.
I disconnected both sides of the battery and when i put it back, it was fine.
RESOLVED: Yes, tightening the battery terminals solved the problem.
I had to take off the pads to get a better grip.
Should I use "battery terminal protector" ? Do you recommend it?
6) They told me that my positive battery terminal is corroded and needs to be replaced also. The problem is;
I never had a problem with my battery until I went to that dealership. A week later, I started to have electrical problems. The alarm system was preventing the car from working etc. After a couple days of inspection, I found the problem as a LOOSE BATTERY TERMINALS !!!
Perhaps I'm just being paranoid, but didn't you specifically ask about your loss of power and alarm issues and then found that the problem was bad/loose terminals?
Then you went to the dealer and they told you they were bad?
Maybe the order of events is simply out of order here, but if not, this is funny.
Old Dec 8, 2012 | 10:30 AM
  #86
No actually what matters is the order.
1) I went to dealer for a safety recall.
2) They inspected the car for free. (Thanks I guess? ) and told me that I need to replace my positive battery terminal
3) And then I started to have alarm issues etc.
4) I found a solution to that problem by posting here. The solution was tightening the terminals.
Now It makes more sense, I hope.
Also idk what is going on but almost all of my threads collected under this thread. Am I not following the forum rules?
Old Dec 8, 2012 | 05:46 PM
  #87
asadali91's Avatar
G35's are known to burn oil, keep some extra oil and when you do your changes try lucas with it aswell or any other oil treatment to extend the life it helps a little but if you have an MT especially youll be topping up that badboy.
Old Dec 8, 2012 | 09:24 PM
  #88
Tune up and throttle body cleaning experience
Today I tuned up my car with 3M Tune up kit and highly recommend it.
1) First i sprayed one bottle of cleaner directly into the engine via throttle body. It took 15 mins approx.
2) Then i used throttle plate cleaner
3) Last step, injector cleaning and fuel tune up into the fuel tank.
During the process, my idle destabilized and the engine stopped a couple of times. I had to hit the gas pedal to prevent it from stopping.
SES came on, P 0102 aka maf sensor.
I just could not take off the throttle body, so i had to spray onto it. I am sure i cleaned the edges but not the back of it.
Results are still impressive. Idle rpm went down to 600-650 from 850.
Runs smoother, shifts better.
Im in love with my G again
However i am aware of the fact that it will be dirty soon because i could not clean the back of the throttle. I did not have the necessary equipment to take the 4th bolt and did not want to go through learning process for the TB.
Did any one of you experienced such a thing? With the same or a different kit/way?
Old Dec 10, 2012 | 06:38 AM
  #89
rsingerG35's Avatar
You should clean your MAF sensor also.
Old Dec 11, 2012 | 05:35 PM
  #90
DGrantG's Avatar
do you have any oil leaks? If you have some and put synthetic in it, it's only going to leak worse.
I run synthetic in mine and I change my oil filter at 3k and top it off with oil and then change the oil and filter at 6-7k.
I would run conventional oil in your car and 10w30 unless it's really cold where you are.
DRG35R
Jan 31, 2016 07:14 AM
Fox843
Nov 7, 2015 05:43 PM
6spdGspot
Oct 5, 2015 01:55 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
