plenum
Old Aug 23, 2012 | 02:39 PM
Andyl's Avatar
plenum
I was thinking of getting this Kinetix Racing V+ Plenum my question is do I have to do any sort of reprogramming or can I just install and drive?
Old Aug 23, 2012 | 03:03 PM
jninja26's Avatar
Install and drive. I have v+
Old Aug 23, 2012 | 03:22 PM
Andyl's Avatar
Did you notice a difference or not really
Old Aug 23, 2012 | 06:02 PM
Jeff92se's Avatar
Red Card Crew
Kinetix was the worst out of all of them. I had the Crawford V2 and was happy with that. All costs the same, the 5/16" Motordyne spacer is the best. And those are the ones most available used.
Old Aug 23, 2012 | 07:04 PM
jninja26's Avatar
The largest difference was plenum + dyno tune Osiris, for me. The tune really unleashed the potential.
Old Aug 23, 2012 | 07:07 PM
jninja26's Avatar
Your thinking of the Kinetix Intake manifold I assume....the V+ has done well in dynos and comparisons that I have seen.
Old Aug 23, 2012 | 07:30 PM
seymore4's Avatar
m56
There is a huge difference between the polished metal SSV plenum and the composite V+
Old Aug 24, 2012 | 12:32 PM
Andyl's Avatar
so if buying do I get a spacer of the whole plenum it seams if you are going through the work you might as well buy the whole deal. But for $265 for 14H.P. atw doesn't seam to bad
Old Aug 24, 2012 | 12:41 PM
jninja26's Avatar
Agreed. I think he was thinking of ssv
Old Aug 24, 2012 | 12:59 PM
Jeff92se's Avatar
Red Card Crew
I thought the SSV on a na motor lost power and torque on everything but the very high end rpm range?
Old Aug 24, 2012 | 01:07 PM
Jeff92se's Avatar
Red Card Crew
http://www.kinetixracing.com/kinetix...ke_plenum.aspx
Has motordyne put this one to the test?
I don't know what "V4" means though.
All dyno info here:
http://www.motordyneengineering.com/...ed672e69fabc21
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
Oggie.mayes
Sep 27, 2015 04:10 PM
