Do I have the worst MPG ?
Old Aug 27, 2012 | 04:55 PM
Ultraslan-ny's Avatar
Exclamation Do I have the worst MPG ?
Hello guys,
I just bought my car. 04 G35X with 76K and replaced one front wheel bearing, all new tires, rotors and brake pads, new castrol edge oil, new air filter, alignment etc.
So far the car drives smooth, tranny oil looked good but I have a really bad MPG.
I filled up with regular gas this time and mostly drove in the city.
I did not push the gas more than 4.000 RPM and its %80 city and %20 hwy (60 mph avg.) driving mostly AC on.
The road computer shows 13.6 MPG, half tank almost gone within 117 miles.
So is it normal or what can I do to make it better?
Old Aug 27, 2012 | 04:58 PM
Drew113's Avatar
Ban Hammer Expert
don't use normal gas, use at least 91 octane
is that 13.6 mpg combined that your getting?
Old Aug 27, 2012 | 05:10 PM
I will switch to 91 with the next tank. Yes combined 13.6...isn't it too low? I read people getting 18 in city driving and 25 on hwy.
Old Aug 27, 2012 | 05:19 PM
jninja26's Avatar
I get 24mpg combined (15gallons=360miles) in my Osiris tuned, Stillen CBE, tube k&n, new Spark plugs, Synthetic oil,91 octane...2005 cp 6mt...50/50 city-hwy
Old Aug 27, 2012 | 05:33 PM
dofu's Avatar
20 Year Member
Have someone check your timing. While the timing chain never needs to be replaced, it could have advanced or retarded itself somehow.
Old Aug 27, 2012 | 05:45 PM
Timing was the only thing that I had no doubt about when I was buying the car since its chain.
If that's the issue, damnn.
Throttle body? Spark plugs? would these help at all?
Old Aug 27, 2012 | 05:52 PM
bluedevils95's Avatar
Also reset your ecu
Old Aug 27, 2012 | 05:54 PM
dofu's Avatar
20 Year Member
I'm not 100% certain this is the best thing to do, but I would get the car onto a dyno to see what's going on.
Old Aug 27, 2012 | 06:05 PM
jninja26's Avatar
You can try using MAF cleaner, reset ecu, definitely change spark plugs if you dont know their replacement history.
Old Aug 27, 2012 | 06:09 PM
joedaddy1's Avatar
80% city.. if it's a lot of stop and go.. i can see it happening..also.. make sure your tires are inflated properly.. ~35 seem to be a good mix.
Old Aug 27, 2012 | 06:14 PM
I will order spark plugs rightaway.....
now I have to look up how to reset ECU, and where to spray the maf cleaner...
any other idea yet?
also in this thread first 3-4 replies are almost as bad as mine. Should that be a relief for me or they just don't care about mpg? https://g35driver.com/forums/g-spot/...s-mileage.html
Old Aug 27, 2012 | 07:42 PM
mikep415's Avatar
I'm on the same boat with poor milage but i mainly drive city to and from work. I mostly drive locally and lots of stop and go...plus a heavy foot on the gas sometimes.
Old Aug 27, 2012 | 07:50 PM
jayflyxx's Avatar
I'm averaging about 18.5mpg in my AWD.. and I use premium, it's about 60% hwy 40% city for me.
Old Aug 27, 2012 | 08:24 PM
jninja26's Avatar
I've never gotten less than 20mpg combined....and since my most recent tuneup 24mpg combined city/hwy (75-80mph avg...on hwy )
Old Aug 27, 2012 | 08:31 PM
5150DS's Avatar
Make sure you stick with ngk platinum or iridium spark plugs.
