G35 sedan drive shaft problems HELP!!!!
Old Sep 25, 2012 | 08:10 PM
chefpique's Avatar
I have an 03 g35 sedan (two wheel drive) and it needs a u joint or a driveshaft. A shop told me that they can replace the u joint but Infiniti said they can only replace the entire drive shaft. Does anybody on here have any experiencewith this and can you advise?
Old Sep 25, 2012 | 08:20 PM
JaE35's Avatar
Moderator
G35 Sedan
sounds like you just need to know where to look for the part? Check out slidegood or ebay...DS's are pretty cheap and come with what you need
Old Sep 25, 2012 | 10:29 PM
chefpique's Avatar
G35 driveshaft
I'm not concerned about parts availability, I'm concerned about whether or not it's acceptable to replace just the u joint instead of the entire drive shaft. Infiniti won't do just the joint but I found an independent shop that will. Any experience with this? I'm a decent shade tree mechanic- is a drive shaft replacement difficult?
Old Sep 26, 2012 | 08:06 PM
AARONHL's Avatar
What symptoms are you having with the busted U-joint?
Old Sep 26, 2012 | 10:54 PM
03IvoryDragon's Avatar
A u-joint is a u-joint. Shouldn't be too bad but while you have it apart might as well replace them all!!!
chinee
Jun 10, 2024 07:48 PM
vmcarbuyer
Oct 12, 2019 12:42 PM
R350k5
Oct 1, 2015 08:41 PM
ClwMike
Jul 23, 2015 12:55 PM
Ninjay16
Jul 20, 2015 01:21 AM
