Mud flap Remover 10mm
Old Oct 12, 2012 | 03:21 PM
neo_anderson302's Avatar
I'm having an issue with removing the front mud flaps. I removed the two screws but the 10mm screw is seized up on the metal clip. Everytime I turn the screw the whole assembly turns twisting the liner its attach to. I'm unable to hold the clip while untighting.
Anyone else have this issue?
Old Oct 12, 2012 | 04:55 PM
Tolboothwilley™'s Avatar
inside is a extruded U-nut - so if you try to put some pressure on that to hold it still while turn the screw out it will come out... probably a pain but you'll get it if you keep trying.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
dcsbh1
Oct 1, 2015 03:15 PM
