Leaking valve cover, replace gaskets?
Old Nov 9, 2012 | 10:46 AM
g35indafuture's Avatar
I found out a few weeks back from my dealership that I had a leaking valve. I plan on purchasing from the dealership the oem replacement valve cover left and right tommorrow. Should I also purchase the valve cover gaskets?
Old Nov 9, 2012 | 02:56 PM
yosip1115's Avatar
I would have definitely started with replacing just the gaskets... But yes, you need to replace both.
Old Nov 9, 2012 | 07:00 PM
saywat?'s Avatar
^depends if the leak is from the outter gasket or the spark plugs. but OP didnt specify
Old Nov 12, 2012 | 02:48 PM
KingoftheRoad1's Avatar
There is no reason to change the valve covers for now, just change both valve gaskets. The gaskets act as a seal for the engine. But if your spark plug is contaminated with oil, you need to change the valve covers which can be expensive.
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
Ken167
Aug 7, 2015 11:12 AM
ghost_g35
Aug 7, 2015 10:31 AM
newg37
Jul 26, 2015 09:32 AM
lemmy999
Jul 25, 2015 12:13 PM
