Slow tire leaks on 3 tires....ARGH!!!!!!!
Old Jan 7, 2013 | 07:47 AM
  #46
Mustang5L5's Avatar
Originally Posted by mikeee2
The weather has been pretty cold recently. Car is always in garage. Outside at night in the 20s so garage is prob in the 40s. Losing 1 or 2 psi a week is that normal? I guess 1 is but 2?
<nerd alert>
I'd say 1psi per month is normal assuming constant ave temps. A drop from 40 to 20 degrees would also give a 1-2 psi drop as well. Depends on tire internal volume and pressure
Reason you lose pressure while sitting (assuming no pressure drop) is because air is 78% nitrogen and a balance of trace gases (Oxygen, helium, etc). The smaller trace gases can escape easier through pores in the rubber, so that's why tires lose pressure over time.
Filling the tires with 100% nitrogen can help slow leaks waaaaaay down due to Nitrogen being a big *** M'F'er.
Of course, this a band-aid solution to your issue, but one worth exploring if you are at wit-ends on your leaks.
Old Jan 7, 2013 | 01:23 PM
  #47
mikeee2's Avatar
Originally Posted by Mustang5L5
<nerd alert>
Thanks for the info. I took it to the same shop this weekend. They found leaks on the bead again for those two tires. They remounted and applied the bead sealant again. Hopefully this is the end of it. Will check this weekend to see if it loses anything.
Old Jan 7, 2013 | 07:52 PM
  #48
asadali91's Avatar
take the wheels off the rim and submerge in water just so u can find exactly what the problem is, take it from there bro.
chinee
Jun 10, 2024 07:48 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
