Tiptronic 2004
ok here it goes.
Me and my gf both have same cars 2004 sedan at.
But the difference is her auto tranny is different,my MM mode has the option of the highest gear,so basicly if it says 3 that mean it will not shift past 3,but in her can you can actually be in the gear you want.production dates are 2003 and are off only by a 2 month.
Is the the ECU that is different or something else,any info would help.
Thank you.
Thank you.
could you explain by evil reflash?
On my 04.5, I can select what gear what I want to be in, but it's still electronically limited. For example you can't put it in 5th if you're only going 20 mph. I'm not exactly sure what your issue is, so if it says 3 for 3rd gear on your dash, you are unable to upshift? Accelerate to 25 mph to shift from 3 to 4, that's the speed the ECU requires
no no no....ok you know how,will say on old cars you have p r n d 4 3 2 1 well if you select 2 for example it will not shift past 2 but only 1 and 2....well my MM mode acts the same.
ill be driving in 3
, will say 60kmh and if i floor it it will downshift to 2 and then to 3 but it wont go pass 3...
do you know what i mean
ill be driving in 3
, will say 60kmh and if i floor it it will downshift to 2 and then to 3 but it wont go pass 3...do you know what i mean
I typed ecu, but autocorrect made it evil.
Mine does the same thing. Not that big of an issue. Just note how fast you are going and what gear you should be in. Downshift carefully and you shouldn't see it as a problem. Also if you let your foot go slowly down on the accelerator and let the RPMs climb by them selves then you shouldn't mix up your manual mode.
well the reason i was asking is,if i am on the highway or in the city in mm mode and i want to pass someone or just accelerate,i didnt want it to downshift.
2nd i kind of want to hear my exhaust note in the low rpm a little bit more
and 3 will ECU swap fix this issue?
p.s and its easier to do this,otherwise it downshifts when you dont want it too:L(
http://youtu.be/FEzSiUrGJh4
<iframe width="420" height="315" src="https://www.youtube.com/embed/FEzSiUrGJh4" frameborder="0" allowfullscreen></iframe>
so if i swap a ecu for 2004.5 that wold fix my problem then*
