Need some help regarding rain and a loss of power
Old Jan 12, 2013 | 03:26 PM
BJD275's Avatar
Hey all,
Last month I had a knock sensor go out. It was fortunately the cheaper knock sensor (there are two one is 150 and the other 40 pending on the number on top). I had it all replaced and had to reprogram the throttle body at Nissan. It ran fine untie it rained. Every time it rains and hits puddles the car loses power and wants to stall. Making the same power loss as when my knock sensor was bad only this time it is not throwing codes. Any body know what this could be?
Thanks,
Brad
Old Jan 18, 2013 | 05:10 PM
BJD275's Avatar
Just had it happen again coming out of the car wash. This time it threw a code for 02 sensors (bank 1 and 2) and a knock sensor (which was already replaced). Nissan couldn't figure it out and said to take it to Infiniti. They said none of those would cause the issue I am having that something has to be getting wet.
Old Mar 12, 2013 | 05:33 PM
StephenG's Avatar
I have a 2008 G35xs and i also lose power when it rains. Does anyone have a solution? this is very annoying.
Old Mar 12, 2013 | 06:00 PM
BJD275's Avatar
After around 2 thousand dollars I got the problem fixed. O2 sensor had a frayed wire causing the system to short out. Have them check the wiring.
jeffbdye
Jun 1, 2018 03:51 PM
G35xdriver04
Nov 7, 2015 08:31 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
vamarris
Sep 26, 2015 12:56 PM
