4th fuel pump in 6 months
Old Jan 21, 2013 | 03:14 PM
Kalvert's Avatar
Ok this is getting retarded, i have replaced 4 pumps in 6 months...even put one from mine in there and it went bad too. it has extended crank,then once started idles bad then 15 seconds later smooths out...whie driving you can feel it cutting out like its not getting enough fuel. when i replace it, it will run awesome for 2 months then back to **** again! Swapped relays,scanned for codes(no codes found) I cant figure this out! any help is awesome!
Old Jan 21, 2013 | 04:01 PM
GFly07's Avatar
Sounds like an electrical problem bro, check the resistance in the wires. How many amps its drawing.
Old Jan 21, 2013 | 05:22 PM
Songle6MT's Avatar
Clean the tank when you replaced them?
Old Jan 21, 2013 | 05:34 PM
Kalvert's Avatar
Yeah on the 2nd one, changed sock twice...starting to think it may be the module assym
Old Jan 24, 2013 | 05:03 PM
TunerMax's Avatar
G35
What is the fuel pressure doing during these issues
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
Rhinos7777
Sep 6, 2015 05:36 PM
