New Exhaust, AT Shifting different.
Old Jan 23, 2013 | 04:02 PM
LoSRx7's Avatar
2004 g35x AT with Berk HFC and Stillen Cat-back.
When driving in Drive, the shifting is happening earlier 2k-2,5k range, making the car a little sluggish. Doesn't even stay in 2nd long. When I manually shift, the car goes fine. Also, the mpg is less then stock, but it's worse when I drive it in D.
Only other mods I have done, are intake, and the grounding kit (no ground wire to transmission).
Any suggestions in getting the tranny to shift better?? besides going back to stock
Thanks,
-Carlos
Old Jan 23, 2013 | 04:34 PM
5150DS's Avatar
Reset the ecu by unplugging the battery overnight.
Old Jan 23, 2013 | 04:39 PM
LoSRx7's Avatar
K I can try that.
Old Jan 24, 2013 | 02:45 AM
DrivenG's Avatar
If the battery trick doesn't work follow the instructions in this thread for a true ECU reset. Takes some practice to do right don't give up after a few failed attempts.
http://www.6mt.net/forum/performance...rocedures.html
Old Jan 24, 2013 | 10:16 AM
nism0b0y's Avatar
None of the wires under the car got damaged during the install did they. I just put a Megan racing one on my car on Saturday with no problems.
Old Jan 24, 2013 | 10:21 AM
LoSRx7's Avatar
I had an engine code for front driver side o2 sensor, after the exhaust install, so I replaced both of the front o2s. Other then that, I've had no codes appear.
Hopefully tonight I'll have a chance to unplug the battery overnight, but I might have to wait till the weather is over 20 in the early morning. -2 this morning hahaha.
Old Jan 24, 2013 | 02:21 PM
nism0b0y's Avatar
Sounds like the car is going through its re-learning process after the o2 sensor switch. If the unplugging the battery trick doesn't work I'd say give it a couple weeks/ few hundred miles and see if it works itself out. That's what I've done when I was getting a code for my crank position sensor, I replaced it and left the cel on till it turned itself off in a few days (or a week I can't remember lol)
gatorglaze
Sep 19, 2015 12:06 PM
Albanian122
Sep 12, 2015 04:02 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
