Multiple Problems with My 04X
Old Feb 14, 2013 | 01:39 AM
Father of Twins's Avatar
I have multiple issues with my car and have reseached all of them thouroughly prior to making this thread. I have listed them in order of annoyance.
1. After the car get warm there is a hissing noise from the engine bay when the car is sitting and idling(will update with a video after I get out of work this morning). It sounds like a vacum leak or something of that nature, but I cannot pin point where it is coming from. This started after I took it to the carwash and sprayed under the hood to clean it up a little bit.
2. I had a hung caliper on the left rear and changed the caliper rotor and pads for that corner a couple of weeks a go. A soon as I pulled out fo my friends garage I had BRAKE/SLIP/VDC light on the dash. The brake fluid is full and this does not affect the performance of the brakes.
3. The airbag light is blinking a steady blink in 1 sec interval. This showed up after we pulled the seat to weld the seat braket after it broker for the second time. I thought the braket broke due to my being a big guy 6'5" and about 325lbs, but apparently it it pretty common for our cars.
I only want to get these issues fixed because we will be selling the car due to the arrival of twins in May/June. It not really feasible to get three car seat in the G(We already have a 4 yr old).
Any info you be greatly appreciated, thanks.
Old Feb 14, 2013 | 09:20 AM
Chris C.'s Avatar
1. Don't know don't care.
2. Either you damaged the wheel speed sensor, the ABS rotor ring, or they could both just be dirty.
3. Obviously you either left the key on or cycled the key while the seat was unplugged.
Old Feb 14, 2013 | 11:35 AM
Andyl's Avatar
3. there is a recall for the airbag lamp look it up or call your local dealer it is a 30 min. deal
Old Feb 14, 2013 | 12:21 PM
Mustang5L5's Avatar
Recall is for the passenger seat, but I seem to believe he removed the driver's seat. If that's the case, it won't help him any.
There is the driver's seat airbag that is tied into the system. Verify you plugged the harness for this back in. It may be separate from the main seat power harness
For #2, verify the ABS wheel speed sensor was not unpluged, damanged, bent or otherwise "hurt".
Old Feb 14, 2013 | 01:47 PM
G35CO's Avatar
3. After you confirmed all wires are connected you can do a manual reset for the air bag light.
Old Feb 20, 2013 | 12:06 AM
Karlow's Avatar
Search on line for the air bag light reset procedure, It worked for me,
Old Feb 20, 2013 | 10:40 AM
yosip1115's Avatar
The airbag light reset does not fix my flashing airbag light in my 05'X...I've never taken out any seats or otherwise touched the airbag system.
I've never changed just one pad... that would make my car unhappy too.
Old Feb 20, 2013 | 03:05 PM
Mustang5L5's Avatar
Have you had the airbag recall performed? If not, you might want to look into that.
Old Feb 20, 2013 | 04:38 PM
yosip1115's Avatar
Thanks dealership... I'm just learning of this now even though I went in just last month to get scanned for a wheel speed sensor. Scary.
Old Feb 22, 2013 | 12:27 PM
G350RT's Avatar
i kind of go the same problem with the air bag light flashing but i never did anything remove the seats or did anything with the air bags. I dont even know how it turn on but i was using the tip tronic to race this other lexus and after i got done racing the air bag light started blinking. Any help????
thanks
Thebaws11
Jul 2, 2021 11:36 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
wuzz-upp
Oct 3, 2015 04:21 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
