Hello, I'm new to this forum, and I have a quick question.
Old Mar 3, 2013 | 02:54 PM
tyonnaaa's Avatar
I own a 2003 G35, and love it to death.
About two weeks after I bought it, there was a rattling noise coming from the front left wheel. It's not a constant rattling noise, it usually happens when I hit about 55mph and when I reach around 80, my car feels like it's going to fall apart. I was just wondering if anyone else has heard of this problem, and what it could possibly be?
Old Mar 3, 2013 | 10:00 PM
roadganstah's Avatar
Search the forums for compression rod issues, this is a very common problem seen with these cars. Look if it is similar to your problem.
Old Mar 3, 2013 | 11:05 PM
Shanes_G's Avatar
You have brembos?
Old Mar 3, 2013 | 11:52 PM
5150DS's Avatar
Unless he has a coupe and accidentally posted in the sedan forum, probably doesn't have brembos. I would guess the ever common wheel bearings.
Old Mar 10, 2013 | 04:48 PM
tyonnaaa's Avatar
Thanks! I'll definitely have to check it out. I thought maybe my suspension was just loose on that side. If I can't figure it out by today, I'll have to take it to a garage.
tyonnaaa's Avatar
I have a sedan, and I'm not a he.
Old Mar 10, 2013 | 05:21 PM
Swivel's Avatar
Moderator
Well that's two points in your favour...
Old Mar 10, 2013 | 05:30 PM
JaE35's Avatar
Moderator
G35 Sedan
Tie rods! Have the wheel jacked up and see if there's any play in the wheel by wiggling it...A symptom of a worn tie rod will make you feel as if the wheel is floating. Could also be bushings, fairly easy to have eyeballed
Old Mar 12, 2013 | 01:29 AM
Karlow's Avatar
First things first, how many miles on her?
If you can put her up on stands, check the front wheels.
Up down, left and right, and rock top to bottom.
You should not get much movement at all.
KP
Old Mar 13, 2013 | 09:44 PM
TunerMax's Avatar
G35
WIN
Old Mar 15, 2013 | 08:44 AM
tyonnaaa's Avatar
KP
A little bit over 111,000. We're getting new tires put on the front tonight, so hopefully whoever puts them on will be able to figure it out. I hope it's nothing too serious.
chinee
Jun 10, 2024 07:48 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
Frostbite91
Aug 20, 2015 07:20 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
