window rattles
Old Mar 12, 2013 | 03:58 PM
Karlow's Avatar
window rattles
I have a new question for you guys.
The window on the divers side rattles when you close the door if the window is down.
It's fine when the window is up. Have any of you guys fixed this problem?
All of the windows and doors work great! Something is lose inside. Also am I going to have problems if I try to remove the door panel? I know on an e36 they fall apart, & that's a a problem. What about the G35? Will break a bunch of plastic tabs or something?
Help guys
Old Mar 12, 2013 | 05:34 PM
Blue Dream's Avatar
I drove ttrank's car solo
The door panel comes off easily. You will need to unscrew 2 screws in the door pull, take out the screw under a little plastic tab behind the door panel, and pull the panel from the bottom to get the clips out and lift up. Be careful with that and you shouldn't break any tabs and there are 2 electrical connectors and 2 manual connectors you will need to disengage.
Old Mar 23, 2013 | 01:18 PM
Gsedan_760's Avatar
Not sure if you fixed it already, but it sounds like your bolt(s) have backed out from the bracket that holds the glass in place. Tighten that up and your issue should then be resolved. (just did it on my girlfriends Altima the other day)
Old Mar 23, 2013 | 11:03 PM
Karlow's Avatar
Sweet, In have not pulled the panel yet.
Old Mar 25, 2013 | 10:18 PM
Karlow's Avatar
Sweet, problem solved
Great, you have to love cars with reliable problems. I pulled the door panel today. It was no problem. Two screws dropped out, and one was lose! Bota-Bing problem solved. Now I can close the door with the window down and it does not sound like a 65 chevy POS Pu! Thanks guys for the assist.
KPenson
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
