VDC light..is it on when I turn it off for RWD?
Old Apr 3, 2013 | 04:05 PM
B T's Avatar
B T
cut the orange wire going to your yaw sensor and see if it comes on,
Old Apr 3, 2013 | 05:28 PM
TunerMax's Avatar
G35
http://nicoclub.com/fsm
Locate fuse. Prosper.
Locate diagnosis for ATC/VDC, locate symptoms, follow troubleshooting to root cause. Prosper.
Also the 'bulb' for the VDC is not a 'bulb', it's an LED, and is very, very unlikely the reason why the light isn't coming on.
Hope that helps !
Old Apr 4, 2013 | 08:11 AM
Mustang5L5's Avatar
Did you buy this car modified??
I wonder if the revious owner did any "mickey-mousing" to permanently disable the VDC
Old Apr 7, 2013 | 11:32 AM
Jazpex's Avatar
Not truly off unless u pull the vdc fuse or set up a toggle. I had mine on a toggle so people knew when it was on vs off.
Old Apr 10, 2013 | 12:53 PM
Tbizzy1985's Avatar
Just curious as to why you want it off if you have AWD? Only time I have ever turned mine off was when I was stuck in snow.
Old Apr 10, 2013 | 03:55 PM
Mustang5L5's Avatar
Drag racing (at the track)
At the track, i had to turn mine off. A little wheelspin on the start (still possible even with AWD) and your run is done.
But other than racing, or snow..my VDC is always on.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
quikrotary
2nd Gen (V36) Sedan
11
Nov 19, 2015 05:14 PM
MThawkins86
Oct 24, 2015 02:07 AM
