Whining humming sounds
Old Apr 19, 2013 | 01:56 PM
semery7's Avatar
I have posted a video of someone elses that shows the same sound.
I thought it was a power steering because my the previous owner had put in power steering fluid before selling it to me when they should have used tranny fluid. Since then the sound is still happening....This sound also tends to happen after driving for a little bit and then immideiately shuts off when i turn the car off and when i turn it back on right away the sound is gone. Any help would be greatly appreciated
2003 g35 sedan
Old Apr 19, 2013 | 04:06 PM
roadganstah's Avatar
Have you tried AC On and Off to see if it makes a difference?
Old Apr 19, 2013 | 04:17 PM
semery7's Avatar
I have tried that yes. I didnt make a difference. Thank you tho
Old Apr 19, 2013 | 08:46 PM
Mosheh1am's Avatar
Radiator fan?
Old Apr 20, 2013 | 10:35 AM
Blue Dream's Avatar
I drove ttrank's car solo
Who told you that tranny fluid needed to be used here? This is straight from my owner's manual:
Check the fluid level in the reservoir tank.
The fluid level should be checked using
the HOT range at fluid temperatures of
122 to 176°F (50 to 80°C) or using the
COLD range at fluid temperatures of 32 to
86°F (0 to 30°C).
CAUTION
 Do not overfill.
 Use Genuine NISSAN PSF or equivalent.
Of course PSF refers to power steering fluid, my suggestion is to replace the fluid with PSF. Once you get the appropriate amount of fluid in the system, with the car on and in park, turn the steering wheel side to side as far as it will go 15-20 times. Often, this will purge any air in the system and get rid of the whine if the PS system is the cause of your noise. If the noise still persists, take the car out for a short drive to really heat up the fkuid, take it back to the house, and repeat the side to side action.
Good luck with your fix and let us know if it gets taken care of.
Old Apr 20, 2013 | 01:57 PM
3truman's Avatar
I have the same problem right now! I just changed my radiator this weekend and when tollboothwilley gets back in town im gonna help him change his radiator and then see if we can figure out a solution to this problem. I hate this noise!!!!!
Old Apr 22, 2013 | 02:30 PM
semery7's Avatar
86°F (0 to 30°C).
CAUTION
 Do not overfill.
I used dexron 3, sorry I should have specified. I flushed it completeyl 3 times and it didn't make a difference. I went to Canadian tire and they said it was the alternator making the sound and then nissan said it had to do with the timing chain.
Old Apr 22, 2013 | 02:48 PM
semery7's Avatar
Have you isolated the problem? Keep me posted! I can't handle this sound any more.
Old Apr 9, 2014 | 03:59 PM
shnasnn's Avatar
I have the exact same noise coming from my 05 G35. I am thinking it's either the alternator or the belts. Did you figure it out with yours?
Old Apr 9, 2014 | 04:52 PM
Mosheh1am's Avatar
Your belts are wearing down and need replacing soon. I would order the replacement kit from Z1 with the idler pulley delete.
http://www.z1motorsports.com/350_g35...oducts_id=7252
Old Apr 10, 2014 | 05:13 PM
JeromeG35's Avatar
My car makes the same noise. Driving me nuts did you find out what it is? Just read online that, this person changed the oil filter and inside was gone. My car to is in need of an oil change. Will post update when it gets done
Old Apr 27, 2014 | 12:08 AM
AARONHL's Avatar
My car just started making the same noise
What is this noise coming from? Strange noise coming from engine. You can tell the noise is more pronounced when the camera is moved towards the front wheel well. You can hear it from each wheel well, sounds like it is coming from under the car. Happens at idle after revving the engine a little bit. What is this noise coming from? Strange noise coming from engine. You can tell the noise is more pronounced when the camera is moved towards the front wheel well.
Old Jun 27, 2014 | 04:28 PM
pootie.teng's Avatar
Did anyone figure out what caused this stupid noise issue?
My '05 G35 is making the same sound and I can't figure it out and its driving me crazy....
Old Jun 27, 2014 | 07:06 PM
mindbeats's Avatar
Hey I just got it. I had both my rear wheel bearings changed an alignment and that did the trick crazy sound gone. Hope this helps everyone
Old Jun 27, 2014 | 09:45 PM
Mosheh1am's Avatar
Its your under drive belts, they're wearing out.
