Can i run staggered tires on a g35x?
Old Jun 6, 2013 | 09:52 PM
Rgscott67's Avatar
Can i run 225on front and 245 on the back(coupe setup) on a g35x?
Old Jun 6, 2013 | 10:29 PM
jgryguc's Avatar
I would think that it is possible if you keep the overall tire circumferences the same (or as close as possible). Would I do it? Probably not the negative things that can happen outweigh the positives. The center diff on most 4wd/awd cars does not really like having different tire/wheel weights, grip levels and offsets. Do you plan on running the same size rims front and back?
Old Jun 7, 2013 | 07:56 AM
Mustang5L5's Avatar
Width.....yes.
Diameter...no. Whatever tire sizes you end up choosing, run through a tire size calculator and see if the diameters are the same.
When the computer locks the center diff to 50:50 ratio, the front and rear wheels really need to be the same diameter otherwise damage could possible occur to the differential.
Old Jun 9, 2013 | 05:57 AM
jeggo's Avatar
Originally Posted by Mustang5L5
Width.....yes.
This.
That's why I'm actually looking for a spare tire that will match my set up as well as I don't want to **** up the diff if I need to use my spare.
Also:
http://www.rimsntires.com/specs.jsp
vitamin.v
Nov 7, 2019 06:10 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
rping
Jul 26, 2015 09:53 PM
