03 Sedan Condenser FAN not working.
Old Jul 6, 2013 | 01:45 PM
ivinio's Avatar
Hey guys, Let me know if you or anyone you know have had same issue with the condenser fan and how you or they resolved the problem.
My car has one huge Fan behind the radiator (clutch fan) and i also have smaller electrical fan in front of the radiator (condenser fan) and that sucker stopped working. AC blows ice cold air, but when i stop at traffic light engine temperature rise up and it goes over 225F and my normal engine temperature is 182/185 with no AC on. (with weather temperature 80F 90F)
No power goes to the condenser motor fan, i have checked for blown fuses in all 3 fuse boxes (one in cabin, one is under the hood in front of the battery and one behind the battery) they all good. I traced the wire from the motor to the fuse box, no visual damages and there's no reason for it either.
Some said it could be the relay, there's a bunch of relays in the third fuse box but i don't know which one is for the condenser. I need to find which relay is for the condenser so i can test it or replace it and that would be my last resort.
What do you think this is?
Thanks for taking your time.
Old Jul 10, 2013 | 09:17 AM
KingoftheRoad1's Avatar
It could be the fan thermostat failed to work properly. A bad thermostat stops the fan from working.
Old Jul 10, 2013 | 10:23 AM
JaE35's Avatar
Moderator
G35 Sedan
yea, maybe it's the thermostat
Old Jul 12, 2013 | 02:25 AM
slikmo22's Avatar
Check ur fan motor...it was a known issue with the coupes they probably have the same motor in the sedans.
Old Jul 12, 2013 | 01:41 PM
ivinio's Avatar
Installed new motor 2 years ago. The thing is, that no power goes to motor. It's like there's an issue with a wire, fuse or relay but they all good.
I know my AC condenser fan should kick in as soon as I turn the AC on. Im thinking to connect word to AC so I don't overheat engine by accident. Until I find the problem. YAY or NAY?
Old Jul 12, 2013 | 01:47 PM
ivinio's Avatar
I installed new thermostat, New radiator, New cap, New houses last summer. My clutch engine fan spins as soon as I start my car and will go to a higher speed once engine temperature rises and its not electric. AC fan is electric and power does not travel to it. I might just rewire the whole thing.
KevinnnVo
Oct 14, 2024 04:33 PM
nettcar
Aug 25, 2024 11:59 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
yassy
Aug 3, 2015 12:24 AM
justgotg35
Jul 19, 2015 12:33 PM
