People with lowered sedans
Old Feb 2, 2005 | 04:59 PM
BrianV's Avatar
Originally Posted by oh-dawg
For you guys with the negative camber, is it that way because there is no more adjustment for the camber (maxed out)? or did you guys set it that way?
Basically, I just want to know if lowering the car, say, 1 inch, is going to give it negative camber issues and inner tire wear..
1" and you'll be under 2 degrees of negative camber. Anything over 2 degrees and you'll be significantly reducing your tire life. I think 1 to 1.5 degree of negative camber is the best as a little negative camber can slightly improve your handling characterisitics.
Old Feb 3, 2005 | 04:40 AM
skeleton_cru's Avatar
Sedan
It's because there is no more adjustment. You may have camber issues after lowering your G, just something to think about.
Old Feb 3, 2005 | 02:45 PM
Dan_1's Avatar
I have Nismo Type S Suspension on mine, and had a alignment done to it afterwards... tracks straight as an arrow...
By the way I also had the Stillen rear camber kit put on also....
Old Feb 3, 2005 | 04:45 PM
SoCalTed's Avatar
lowered with Eibachs.
got it back to about 99% spec. No pulling at all. Can drive 100mph on the 73S in Newport and can take my hands off the wheel with no issue.... Not that I make a regular habit of this, or for any duration of time...
Old Feb 3, 2005 | 04:56 PM
nuttyprof's Avatar
after lowering, i got my alignment, and the two front wheels cannot be set to the same spec on my car. there is a tad bit of pulling due to this. i dont want to shell out for the camber kit either, so i just live with it. its not that bad.
Old Feb 4, 2005 | 03:58 AM
Audi_2_7t's Avatar
where are u located? i know a great shop in socal
Old Feb 4, 2005 | 06:13 PM
Drv4fun's Avatar
Hey SoCalTed!
Sweet ride!!! I, too, would like my 05 6MT sedan lowered. Which shop do you go to to get your stuff installed? Or do you do most of 'em yourself?
Someday, I'd like my ride to look similar to yours! NICE!
Jusseth
Sep 13, 2020 12:25 PM
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
Xanthan Gum
Aug 6, 2015 10:49 AM
