Trip Odometer Wont Reset - 2005 G35 Sedan Auto Trans
Old Jul 28, 2013 | 08:00 PM
steveobud's Avatar
First time posting, although I have lurked for a while. Hoping that I'm posting in the correct forum.
I have a recently acquired G35 Sedan, 2005, Automatic Trans.The Trip Odometer won't seem to reset when pushing the black button behind the steering wheel. Also won't cycle from Trip A to Trip B. It is looking like perhaps the button/switch is bad, (I hope not), but I'm hoping that there is some reboot/reset trick to get this to work.
Thanks for the assistance.....
Old Jul 29, 2013 | 03:30 PM
05_SkylineSedan's Avatar
20 Year Member
That's a weird thing to fail. That switch has many hidden functions (which I didn't know about until I looked it up just now) including changing the shift-up engine speed (!!) and putting the entire "Combination Meter" into self-diagnosis mode. You can grab your service manuals here:
http://www.nicoclub.com/FSM/G35/Sedan/2005_G35_Sedan/
Start with the one marked "di" for "Driver Information System" and check out the ODO/Trip Meter section.
Old Jul 30, 2013 | 02:25 AM
steveobud's Avatar
Thanks for the link, this looks like a great resource.
I attempted to enter the 'diagnostic mode', but it didn't activate. I'm going to try to remove the fuses that power the Combination Meter, and see if that reboots/resets the meter system.
Again, thanks for the info....
Old Jul 30, 2013 | 07:36 AM
Blue Dream's Avatar
I drove ttrank's car solo
Can you explain where yuo found this or how to do it? I looked in the di section of the 05 sedan fsm and didn't see any information related to the process.
Old Jul 30, 2013 | 12:41 PM
20 Year Member
Sorry, my bad. I was looking at was page 6 of that manual but now I realize they're talking about setting the engine speed at which the "shift-up indicator" flashes - on a manual trans... Never mind...
Old Jul 31, 2013 | 02:31 AM
steveobud's Avatar
Tried removing the fuses that feed the Combination Meter. It appears that the unit is stuck in the diagnostic mode, and it may not be responding when I press the odometer reset button.
Hmmmmm.....
Old Jul 31, 2013 | 02:34 PM
20 Year Member
That's not good. I don't think the instrument cluster is meant to be "serviceable" although there may be some folks here who have busted it open to change the bulb or LED colors? So maybe there is a way to get to that internal switch but I'm afraid it's a can of worms.
Did you buy from a dealer or private party? Might be a dealer question, especially if it's stuck in diagnostics mode. Can you even drive the car that way? Yikes!
Old Aug 1, 2013 | 10:22 AM
steveobud's Avatar
So, I disconnected the battery overnight. The trip odometer condition still persists. When I turn the car on normally, I get the normal warning lights etc., The trip odometer remains on 'Trip A', reads all zeros, and it is unresponsive to any button presses.
When I attempt to invoke the Combination Meter diagnostics mode, I perform the procedure as follows:
Ignition off. While pressing the odometer button, turn ignition to the 'on' position'. Release the button, then press it three times.
Interesting thing is, that the trip odometer briefly flashes the actual stored 'Trip A' mileage value, then returns to all zeros. The odometer is unresponsive to subsequent button presses.
When I've interrupted power to the combination meter, the trip odometer mileage resets to zero. The combination meter does not seem to fully enter the diagnostics mode, (i.e. the LED segments don't light up, etc.).
I believe that somehow, the trip odometer function of the combination meter needs to be 'rebooted', but I'm not sure how that can be accomplished, beyond what I've already tried, i.e. complete removal of power, and trying to invoke the combination meter diagnostic mode.
Thoughts?
Old Aug 1, 2013 | 01:40 PM
20 Year Member
Yeah, weird behavior. If things don't "reset" after being powered down overnight then I doubt any other operation would do it. My guess - only a guess - is that the actual physical switch that is operated by pressing that shaft-type button is either broken, disconnected from the circuit board, or stuck "on" as if it is being pressed continuously. If that's not the case then there may be a logic error happening in the Combo Meter, a black box computer processing type of error. Either way your options are limited.
If you can live without the trip ODO then do that!
Otherwise it's:
A. Tear your combo meter apart and try to get to that switch (lots of work with an unclear outcome - might even bust the unit in the process),
B. Take it to the dealer and see if they have a clue. If they say you need to replace the entire unit then...
C. Buy a used or new Combo Meter and replace the whole thing (expensive, resets total ODO mileage)
I'm out of ideas, sorry.
Old Aug 2, 2013 | 10:35 AM
steveobud's Avatar
Otherwise it's:
I'm afraid that you are correct. The more I observe how it is not working, I think that I was mistaken about the combo meter being responsive to any button presses of the odometer switch. So, it must be a physical or electronic issue with the switch.
I don't like the options of tearing my dash apart, I'd probably do more harm than good, with either a slim chance of correcting the problem, or breaking something in the process, or costing a lot of money.... so I'll just use the trip odometer function of my Garmin, and get over being bugged by the fact that something is not working correctly...
Thanks for the advice.....
R350k5
Oct 1, 2015 08:41 PM
lemmy999
Jul 25, 2015 12:13 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
