Any idea what this is leaking?
Old Aug 18, 2013 | 08:18 AM
trendyblackguy's Avatar
Hey, sorry if this is a dumb question. I've had my 2004 5AT G35 Sedan for a few years now, but I haven't really been under there since 2 weekends ago when I changed out my hub assemblies (side note: a slide hammer is KEY for that project).
Anyway, while under my car I noticed that this was leaking on the driver's side of the car. What is it? LCA? Compression rod? Pictures are below:
Old Aug 18, 2013 | 09:41 AM
redonblack35's Avatar
It's your lower ball joint, I have the same problem. I'm guessing your car slightly pulls to that direction too. It's a pretty straight forward replacement but does require a shop or hydraulic press from Autozone slightly modified to install a new ball joint. Use the search tool above to troubleshoot it, there's 2 or 3 really good posts regarding the matter and replacement procedure. I haven't tackled this myself yet so I can't give you any real first-hand tips but I know it's been said and done here like everything else! Goodluck
Old Aug 18, 2013 | 10:15 AM
Thanks!
Old Aug 18, 2013 | 10:49 AM
AARONHL's Avatar
Some good threads on changing a ball joint
Google search
lower ball joint site:g35driver.com
lower ball joint site:my350z.com
Old Aug 18, 2013 | 11:35 AM
Google search
I just did and found some really good DIYs. I also just ordered the Duralast lower ball joints with a 20% discount + ES dust boots. Overall it came to ~ $125, which is way better than what I saw dealerships were charging for parts + labor.
I'll attempt fixing my issue next weekend. Hopefully that will solve all the suspensions issues I've been having. If not, I'll look into replacing the compression rod bushings next. Thanks guys!
lavtxa
Sep 21, 2015 11:51 AM
Moskvitch
Sep 14, 2015 10:15 AM
Rhinos7777
Sep 6, 2015 05:36 PM
UT G35
Sep 3, 2015 03:58 PM
