Electric seat won't recline!
Old Aug 22, 2013 | 04:42 PM
NikkisG35's Avatar
My '03 G35 has an electric drivers seat. It will tilt forward but won't recline. I accidentally stuck myself in the windshield. I took it to the dealership and they said the switch was bad and it would cost $300 to repair. Does anyone know how to get the seat to recline without actually replacing the switch? My pregnant belly is making it difficult to drive!
Old Aug 23, 2013 | 09:08 AM
Mustang5L5's Avatar
Well yes. It would be possible to purchase an aftermarket switch and rewire it, but it would be very difficult to explain and perform without some electrical experience.
Best best is to find a switch used, and ask someone to swap it for you.
Old Aug 24, 2013 | 10:49 AM
Wi-Z_Sam's Avatar
03's had an awful design for the seat
I have an 03 and the tilt? On the seat stopped working but it was under warranty last year when i bought it
Another note, your seat can only use seats parts from another 03, you could look online and buy the part on ebay probably or a junkyard, but the install is the easy part, probably would take 1 min to unbolt the 4 bolts on the seat, another 10-15 to "switch the switch" out
Old Sep 9, 2013 | 10:33 AM
Obsidian Sport's Avatar
I'm late to the thread, here - but I had the same issue and found previous articles that recommended spraying WD40 into the switch, let it sit overnight, and blow out with compressed air the next day. It worked for me
Old Sep 14, 2013 | 08:34 AM
Echinery's Avatar
Did this really work? Because all my buttons work except the recline button. I'm stuck leaning like a cholo.
Old Sep 15, 2013 | 07:52 PM
NISMonly's Avatar
my 04 stopped working for a couple weeks, then has been working since. I know your pain lol
Old Sep 19, 2013 | 02:36 AM
bmacchi14's Avatar
I had an issue with the recline AND the forward backward movement of the seat on my 06 sedan. I ended up getting electrical cleaner instead of using WD-40. It's quick drying and won't leave residue.
I tried spraying the top of the switches with the cleaner first, but it wasn't able to get deep enough to really clean out the 6 years worth of gunk built up.
From another thread, I found that on the side of the switch, there are two stickers covering two screw holes. I elevated my seat as far as it would go and gave myself enough room to unscrew the screw closest to the front of the car after puncturing the sticker. After that, I was able to lift up the switches enough to spray up into the electrics and give them a good cleaning.
Things have been working like new since.
Old Sep 19, 2013 | 02:54 PM
pjgangsta's Avatar
G35X Revup
spray wd40 on the seat switch????
Old Oct 23, 2013 | 12:33 AM
Chucks 04's Avatar
I had the same issue with my 04 sedan the seat would not recline so I tried the wd40 with the red spray straw. I put the straw in the crack of the switch and gave it a couple of squrits let it sit for a few seconds then started to mess with it. Now it works like new just wipe of the switch when your done.
Old Jan 1, 2014 | 10:58 PM
ItsA..Gthing's Avatar
Guys just got the wife a 03 g35 sedan...Driver side seat wont go forward all the way..The left side track goes slightly forward but right side just pivots the seat to the right instead of going forward..Ideas?
Old Jan 2, 2014 | 08:18 AM
infinitidude's Avatar
Yes sir the plastic gear in the front right seat rail is stripped out. one of two things, you can either replace the whole seat frame assy. or if you search ebay there is a company that sells a replacement gear to fix the issue. Hope this helps
Old Jan 2, 2014 | 12:36 PM
What is the less expensive route? Since you are a tech do you know about what it cost either way? Edit..Found plastic seat track rail gear replacement kit $50.. Is this hard to swap out?
Old Jan 7, 2014 | 05:46 PM
I have never swapped one out because we can only get the entire seat track as a fix. I don't think we can get the gear separately.
Old Jun 11, 2014 | 10:03 AM
G35MissO's Avatar
W-40 Works!
I was about to spend $150 to replace the switch set for my driver's seat. I came across this forum went to Walmart bought the W-40 and a can of compressed air. Sat in the parking lot and shot the W-40 in all the switches, I played with them for about 10 minutes and they all started working. Needless to say, I had a comfortable ride back home. You saved me money,pain & suffering! Thanks!
Old Nov 21, 2014 | 05:15 PM
woodstar's Avatar
electric seat
Dould you tell me where you found the complete assembly? Looks as though I'm going to have to change. The G's have lots problems with electric seats but precious little info on forums
