2005 G35 Sedan "Pings"
Costco fuel... I'm going to run a can of Seafoam through it and try Chevron or Shell gasoline. If that doesn't help I'll have the timing checked.
The car is stock, 57k, I bought it from the original owner at 50k, all service done at the local Infiniti dealer.
It's not a rattle.
Thanks for all your help guys.
CM
It's not a rattle.
CM
It's a possibility that it is the Costco gas. I've had bad experiences with it.
Give it a few tanks of "better" gas before you evaluate. I wouldn't even do the seafoam. Just run some fuel injector cleaner and different gas and see
I used Costco gas for years in my 04 and never had this problem. However, their supply chain is regional, so I guess it's a possibility; winter gas in general seems to cause alot of problems. My guess is carbon buildup or a sensor mis-reading; I'd recommend the fuel injection service the dealer offers. In addition, reset the ECU at the same time.
It's the gas. I last filled with Shell 89 octane, runs like a champ. I guess you get what you pay for. I'm still going to run a can of Seafoam through it just to clean it out a bit.
Thanks for your help!
Carl
Carl
tehmoonrulz
Jul 19, 2015 10:44 PM
