abs slip and vdc lights
Old Dec 25, 2013 | 05:09 PM
pernerat230's Avatar
Exclamation abs slip and vdc lights
I have an 03 sedan, not too long ago I had a problem with my hub on my g while I was taking it to the shop the abs slip and vdc lights came on. I thought It was the hub , so I just let the mechanic change the both front hubs thinking that was going to turn the lights off. So when I got the car the light where still on. I hopped online and googled about it it said I needed to put brake fluid in the reservoir, when I got to the car the reservior was full. Then I kept googling and said that the abs sensor on the passenger front was messed up. So I changed it and really it looked like the hub messed it up the old one, but the lights wont turn off.. could someone help me and tell me how to reset this
Old Dec 30, 2013 | 02:42 PM
3maxima's Avatar
Check for codes. My car did this and I had a code for camshaft position sensor. A new sensor fixed it.
Old Dec 30, 2013 | 04:14 PM
Mustang5L5's Avatar
Any other lights on the dash on?
Old Jan 27, 2014 | 06:17 PM
6spdsedan's Avatar
I have the VDC/Slip light on my 05 6psd. I just replaced rear rotors and brake pads two days ago. brake fluid is good. I still have my light on. I may a bad sensor or module . I will look into it, I'm going to try and hook up a code reader. I will let you know how mine goes.
Mry
Mar 3, 2023 01:03 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
MsFitFern
Aug 9, 2015 02:58 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
Wayne9011
Jul 27, 2015 11:25 AM
