Car stalls with the high powered dryers at end of car wash
Old Jan 19, 2014 | 10:54 AM
Speedster's Avatar
Strange issue that I don't understand, I just installed a stillen cold air intake /z tube combo and MD plenum spacer. Now when I run through the car wash that I always go to, when I get to the end where the high powered blower /dryers click on, the car stalls and I have to restart. Why would that possibly cause the car to die now after my mods?
Old Jan 19, 2014 | 03:25 PM
5150DS's Avatar
Not sure, but it sounds like it can be solved by washing your car at home.
Old Jan 19, 2014 | 05:13 PM
Urbanengineer's Avatar
Maybe it stalls out because your MAF recognizes crazy airflow (g/cm^3) when you don't press the throttle?
Old Jan 20, 2014 | 02:12 AM
dukehotty's Avatar
I was thinking the same thing the engineer mentioned. In for results.
Old Jan 20, 2014 | 08:05 AM
Mustang5L5's Avatar
I would have to venture to guess that the air dryers are somehow forcing air into your new intake system in such a way that causes the car to stall out.
If you want to confirm, put the stock setup back and see if the issue stops.
Chekc your filter also to make sure it's not getting soaked by water being blow in.
Old Jan 20, 2014 | 08:30 AM
joedaddy1's Avatar
do you have the car running during the car wash?
Old Jan 20, 2014 | 09:09 AM
Speedster's Avatar
That does sound like a good reason to why it might stall. I'll have to test the theory. There is no water getting in, everything is dry.
Joedaddy - yes car is running. It's one of the washes where your tires are on a track and the car is in neutral and it's being pulled along the line
mike730
Jan 12, 2018 04:25 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Kal Hamm
Jul 24, 2015 08:55 AM
ClwMike
Jul 23, 2015 12:55 PM
BlackGee35
Jul 21, 2015 07:24 PM
