Tollboothwilley Transfer Case Shield Installed With Super Easy Directions!
Old Feb 5, 2014 | 11:22 AM
The Fixer's Avatar
Hey all,
During the summer I hit a NASTY pothole that cracked the plastic shroud covering the steering rack/lines and transfer case. One screw head actually sheared off so the threaded end is still stuck in the crossmember. I rigged the OEM part up with zipties and it was holding up fine, but I figured I should get a replacement to install in the springtime. Fortunately, I had the good sense to order the Tollboothwilley transfer case aluminum shield - it arrived last week, and I wound up needing it sooner than expected.
Anyway, installation is very easy. First up, remove the original. There are 5 10mm screws holding it in place. - 3 are along the crossmember, and then 1 at each rear corner by the compression rod mounts. I didn't have to remove mine - Mother Nature kindly took care of that on my way home from the store pulling into my driveway over a mountain of plowed ice and slush LOL.
Here's a comparison of the broken plastic OEM one on top, with the Tollboothwilley part below it. Much nicer, and stronger!
And here it is, installed. John also supplied new screws to install it - very nice!
Right now I only have 4 screws holding it in place, since I need to drill out the broken one. That'll have to wait to springtime, since we're getting pummeled this winter with snow. It was 30* out when I installed this in my driveway yesterday, and you can see the piles of snow all around. This part is much stronger than the original, and I don't think I'll have an issue with that missing screw for now.
Enjoy, and for anyone contemplating whether or not to order one - just do it!
Old Feb 5, 2014 | 02:19 PM
srv2nv's Avatar
G35 Sport
Looks good, should hold up much better than the stock one, and I can attest to the strength of these thanks to this horrible winter we're having. I've lost count at how many ice chunks I've taken off the shrouds this winter driving on the highway each day, and I expected a dent or two, but found none when I had it on the lift last week.
Old Feb 5, 2014 | 07:00 PM
Tolboothwilley™'s Avatar
Looks good on your car man!
Old Feb 6, 2014 | 07:04 PM
The Fixer's Avatar
Thanks John, glad you make a great-fitting product for our cars!
EnCr1pt3d
Jul 8, 2019 02:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Frostbite91
Aug 20, 2015 07:20 PM
CrazyLogic219
Aug 13, 2015 06:40 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
