Staggered Rays on G35x
Old Feb 8, 2014 | 11:49 AM
Hcp911's Avatar
This question has been answered many times throughout the years but i cant find a definite or straight forward answer.
If I am getting an oem set of 19" rays 8" in the front and 8.5" in the back and I already have 240-45-19's for the back, what would be the closest to the same rolling diameter for the front?
Just looking for what size tire i need in the front.
Old Feb 8, 2014 | 12:00 PM
5150DS's Avatar
240-45-19
Old Feb 8, 2014 | 01:05 PM
Hcp911's Avatar
Originally Posted by 5150DS
240-45-19
so the tire widths wont make this different?
Old Feb 9, 2014 | 05:52 AM
Blue Dream's Avatar
I drove ttrank's car solo
I think you meant to write 245/40/19. Stick with that size all around or if you want a little skinnier tire up front you can run a 225/40/19 and that will work fine on your X.
Old Feb 9, 2014 | 10:47 AM
melee757's Avatar
http://www.rimsntires.com/specspro.jsp
Old Feb 14, 2014 | 05:15 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
I believe theres a 3% tolerance
Option 1: 235/40/19 & 245/40/19
Option 2: 245/35/19 & 255/35/19
I have found those sizes to be ok with X, If you want to be 100% safe then just do 245/40/19 on all 4.
Old Feb 14, 2014 | 08:11 PM
Gman56's Avatar
Could the difference in rolling resistance cause any problems?
Old Feb 14, 2014 | 09:06 PM
jookyshank's Avatar
I haz hugz to givez
I ran stock setup (rays) directly off a coupe (225/245) with zero issues, the stagger limits are ~5* before vdc has any issues. Unless you go nuts you should be fine
Old Feb 15, 2014 | 10:21 AM
Mustang5L5's Avatar
Keep in mind, while the electronics limits are 3-5%, there are mechanical limitations as well.
The transfer case will experience more slip than usual due to differences in rolling distance. It is designed to take some as in a turn, the front wheels turn a larger distance than the rear wheels. Slip translates to heat, and that's never good for clutch systems. You may want to consider increased fluid changes to your transfer case here.
However, in 50/50 split situations, the extra diameter and rolling distance while in a straight light needs to be absorbed somewhere. Fortunately for us, this situation usually exists when the tires are on low traction surfaces such as snow and ice. I would also think that someone engaging snow mode probably has a set of OEM wheels as their winter wheels and isn't doing so on 19's. Then again, I could be wrong.
Still, it's in your best interest for your vehicle to try and match overall diameters front and rear as best as you can. You make even want to consider selling the rear wheels and buying another pair of fronts to have the same wheel diameter and width front and rear.
Old Feb 16, 2014 | 06:50 PM
TurTLe*'s Avatar
man speaks the truth.
some of these guys replying are only speaking in terms of VDC and not AWD since they own RWD models. just saying... =P
245/40/19 is your best bet all around.
Old Feb 23, 2014 | 07:34 PM
jeggo's Avatar
Okay. I'll thread jack a bit haha I have 18x8 and 18x9 +32 offset all around rims. I was thinking buying a set of 225/40/18 for all 4 rims. Is that okay for my X? I looked at http://www.rimsntires.com/specspro.jsp and if I put 225/40/18 tires the max width for rims it will allow me is 8.5".
Should I be okay with that size of tires? 225mm is 8.5 something so it's just a tad stretch for the 9" right?
Old Feb 24, 2014 | 12:17 PM
Mustang5L5's Avatar
225mm is about 8.8"
Close to 9" but you'll have a slight stretch
Old Feb 24, 2014 | 12:45 PM
jeggo's Avatar
225mm is about 8.8"
Cool then. It shouldn't affect the diameter right?
Old Feb 24, 2014 | 02:20 PM
Mustang5L5's Avatar
Nope, not if you are running 225/40/18 at all 4 corners.
Old Feb 24, 2014 | 05:04 PM
jeggo's Avatar
Awesome! Now I'll buy that set then. Thanks a lot!
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AJC128
Nov 1, 2015 11:55 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
Claudiu
Sep 26, 2015 01:04 PM
