Hi all
The only minus to the outstanding G35 sedan is the fact it is embarrassingly under-tired. I have the 215-55/17 Goodyears on now awaiting them to wear out. Can I get some input as to the largest tires (I want to keep the stock 17x7 5 spokes for now...$$$$ being the reason). Another question is changing the aspect ratio too much (right now it is 118.25). Will that effect any electronic systems (VDC) or not? Thanks in advance!
If you want to keep the stock rims, go with a 235/50R17. The speedometer error is nearly non-existant. The VDC is fine as long as you keep all four tires the same size, and don't stagger them (like the coupe). Another possibility is 225/55R17, which is a little bit larger, but still not too far off on the speedometer, and provides some better summer tire choices. Tires wider than 235 generally want a minimum rim width of 7.5" or 8".
tirerack.com is a good source to figure out what sizes fit and what tires are available in that size.
http://www.miata.net/garage/tirecalc.html is a good resource to make sure you're not too far off on the speedometer accuracy.
I just mounted up Pilot Sport A/Ss in a 235/50-17 and am very impressed so far! I know some G35Ss that have gone with 225/50-17 with minimal differences in overall height, in fact I was initially planning on going with Falken ZE-512 in a 225/50-17 which interestingly, is almost identical to the diameter of the G-Y RSAs (different manufactures have slightly different overall diameters when new for the same size). Another possibilty is a 245/45-17 which I was told would fit our rims with no problem and is still within acceptable limits.
I've heard great things about the Falkens, so if the best bang for your buck is a factor, check them out. See the thread:
https://g35driver.com/forums/showfla...&sb=5&part=all
<font color=green>GG</font color=green>
Gordgee,
I am also thinking up urgrading my tires and or tires and wheels. How does the car ride and handle with the new setup....also my main concern is sterring pull by going wider has it effected that or does it feel the same as the stock size tires even on roads that are more uneven than others. One time i upgraded tires on a 99 accord and it pulled and i only went from a 205 to a 215 on the other hand that was a honda accord which a a totally different car.
Too early for me to tell yet. I haven't had it out on enough variety of roads and so far, we've had 3 days of snow again so the roads are wet. From what I've heard, most people have noticed a slight increase in tramlining, but not so bad that you have to fight the wheel or anything. In the city so far, I haven't noticed any. The steering response is much improved. Tire noise is almost the same, maybe a little quieter than the RSAs. Because the Accord is FWD, I think that that is what contributed a bit to your previous experience with the minor size difference- just a guess though.
Gord
Gord
Re: Tire upgrade?
My experience with Falkens (12 yrs ago)....I grew up in the VI where we have very steep hills and when it rains you actually can have a hard time getting up. The tires that were available sucked. They wore quickly and were terrible in the wet. We on a whim bought some Falkens and they not only wore well but were the best wet weather tire I've ever experienced. The conditions are so different in the states that I never tried them up here. Always wanted to but never did.
Oh and my stock Brigestones suck.
G35s 6MT Garnet Fire, Premium, Aero, Aero Body Kit, Winter Sport<P ID="edit"><FONT class="small"><EM>Edited by smcallis on 05/06/03 03:46 AM.</EM></FONT></P>
The stock Bridgestone's don't suck at what they were designed to do. They're not a performance tire, they're an all-season touring tire. They provide better comfort, and sportier performance, than standard passenger tires, as well as maintaining decent grip in the wet. They're not performance tires. It's kinda like trying to say our cars suck at hauling lumber.
Re: Tire upgrade?
That's a good point...I just looked it up and compared it to the Dunlop Sp5000s that I had on my SHO. The dunlops are "ultra high performance" and as you said the Bridgestones are touring tires... I just assumed that they would have put on a high performance tire on the G. So yes I guess the Bridgestones are good for what they are designed to do. I'm also a bit bummed about the lack of selection we have for our tires. I know there are additional options if we play around with the size but it's still a limited selection.
Oh our cars do suck at hauling lumber ;-).
They do put Goodyear Eagle GS-D's or RS-A's on our cars as well, depending on which option packages you have. I think you get the Bridgestone's with the Winter package -- as the Winter package states that you get all-season tires.
I'd like to get Bridgestone Pole Position S-03's or Michelin Pilot Sports (regular, not A/S), but they don't seem to come in sizes close enough to stock. I'm probably going to replace my tires with Pilot Sport A/S's in 235/50R17 when it's time.
The spring snow and rain Edmonton is getting is a good test for my Pilot Sport A/Ss. Hasn't stopped snowing for 4 days![img]/w3timages/icons/frown.gif[/img] Good thing it's hovering around melting temperature.
This morning's roads had about 4" of wet snow on them. I AM IMPRESSED! So far, the best A/S tire I've ever driven in these conditions, especially considering 235s! Not sure how they are on ice. Also great in the wet going though fairly deep water with no hydroplaning. I guess there's a reason that Michelin tires cost more than most of the competition.
Re: Tire upgrade?
Yes the winter pkg got me the Bridgestones. Not a big GY fan...I had RSA's on another car and they were pretty good in the dry but sucked in the snow and wet and they wore out wicked fast. But all suppliers have good and bad. I love dunlops...the sp5000 but the D60 is terrible in the snow.
