WOT lower power than 80% throttle ? Am I crazy?
Old May 5, 2014 | 02:10 PM
maxxcool's Avatar
Question WOT lower power than 80% throttle ? Am I crazy?
Short version:
2006, g35 sedan, 5at, NO mods 90k-odo .. Just bought it about 3 months ago.
*if* you mash it, leave it pegged on the floor it revs and runs like hell. sweet... but I noticed that when I let off the gas only a smidge.. I feel more push back.
Is the WOT limited in the sedans on purpose ? Is the limited open throttle I keep reading about ? AFM different under wot ?
..the longer version
From a standstill, pushing the accelerator down 'quickly' but not a full on 'stomp' the car launches off nicely and goes through the gears.. but right before speed limit (sub-60mph) obviously you let off the gas.. *that* very moment I let off the gas to stop acceleration I note that there is a measurable push back (g force) *increase* .. until I am around 40"% throttle..
now I thought I was crazy at first, but I have been reproducing it pretty much at will.
I have no instrumentation to apply so do not know the particulars .. but I am wondering if anyone else has noticed the same thing on the sedans with the 5at.. is this a afm thing based on the WOT? Is this the limited throttle protection I keep reading about ??
1st time poster... be gentle
Old May 5, 2014 | 09:40 PM
3maxima's Avatar
I think what you are experiencing is that less than WOT is where the peak torque band is.
Old May 8, 2014 | 10:40 AM
Peoria35sedan's Avatar
Your aren't crazy, WOT is limited by the ecu.
Old May 8, 2014 | 10:52 AM
seymore4's Avatar
m56
+1 and why Uprev tunes are so awesome. PM me I'll explain all how it works
Old May 14, 2014 | 01:22 PM
Marioh's Avatar
I experience the same thing. Thought I was crazy.
Old May 14, 2014 | 09:36 PM
itgogitrev's Avatar
Enlighten us all!
Old May 14, 2014 | 09:42 PM
Urbanengineer's Avatar
My friend, here is the wheel. Now roll it!
http://uprev.com/UpdateFiles/softwar...er%20Guide.pdf
Old May 14, 2014 | 10:55 PM
seymore4's Avatar
m56
Originally Posted by itgogitrev
Enlighten us all!
There is a restriction on the electronic throttle from the factory, one of the most noticeable improvements from an Uprev reflash/ tune is syncing the electronic throttle so you can achieve true WOT at all speeds. This can be done with both a dyno tune, and the etune route
Hasanbaloch
Feb 29, 2024 08:45 PM
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
Silver tiburon
Sep 4, 2015 07:17 PM
linedr89
Aug 17, 2015 05:11 PM
