heated seat is not working
Old Oct 17, 2017 | 06:51 PM
05_SkylineSedan's Avatar
20 Year Member
What year is your car? Coupe or sedan?
Old Oct 18, 2017 | 08:53 AM
3MGunner's Avatar
Veteran: Navy
Will be interested in seeing the outcome of this, my seats both heat up, (takes a while) but the passenger seat button does not illuminate, (found out it worked when i accidentally turned in on when my wife was in the car..she was like why is my A@@ on fire?) I have not bothered to trouble shoot it at all since i don't sit on that side of the car. LOL.
I do know it took 5 to 10 mins for it to get hot.
Old Oct 24, 2017 | 04:27 PM
IllaNoizeTV's Avatar
So the mechanic checked everything and some wires were unplugged in the console. Both seat heaters work I have a 2006 g35 sedan.
Old Oct 28, 2017 | 10:04 AM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Just curious if you'd even use the seat heaters in Florida...
Old Oct 28, 2017 | 10:25 AM
I live in Nashville now. Been here for a year.
Old Dec 18, 2018 | 06:01 PM
04-35's Avatar
2004 G35 coupe
what console? My heated seats don’t work in my 04 coupe the lights come on, one the two switches. Would like to get this fixed
Old Dec 19, 2018 | 09:49 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
I haven't had this problem in either G35 yet but both of my G20's have. It's always the switch that keeps the heated seats from working on my G20's so I grab them out of Maxima's since the G20 is almost non existent in the yards anymore. Pretty easy to test with a multimeter right at the heated seat switch to see if you have power. Just because the light is out doesn't mean there is no power, the lights burn out on them pretty often too.
Old Apr 29, 2019 | 09:22 AM
Preston C's Avatar
g37
Originally Posted by 05_SkylineSedan
But I'm still here. If you can't find the fuse yourself tell me the year and model of your G and I'll look it up for you.
i have a 2010 g37. I think my heated seat is stuck in the “on” mode. How can I fix this?
Old Apr 29, 2019 | 11:07 AM
20 Year Member
If you want to troubleshoot it, the service manual for the (sedan) seats is here:
http://www.nicoclub.com/FSM/G37/Sedan/2010/SE.pdf
Stuck "on" I believe would indicate a bad switch. One seat only? Is the little indicator light glowing next to that switch?
Old Apr 29, 2019 | 12:07 PM
Preston C's Avatar
g37
it is only one seat. I’ll do the trouble shooting. The light is not on.
Old Apr 29, 2019 | 06:07 PM
20 Year Member
Yeah, stuck "on" is a weird one because I think there's a relay involved as well as temp sensors in each seat. Does the light come on if you turn the switch on?
Just to make it more confusing, here's your "Power & Ground" manual:
http://www.nicoclub.com/FSM/G37/Sedan/2010/PG.pdf
Conceivably, you could simply disconnect the plug to the heater circuit under the offending seat...
Old Apr 29, 2019 | 06:33 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
There isn't a high limit temp sensor, the resistive heating elements are sized appropriately for the circuit. The first thing I would do is ensure the seats are actually turning on. Test with a thermometer, ir or otherwise during the coldest part of the day. After 15 minutes there will be a noticeable difference in temp between the two seats.
If it is stuck in the ON position I would start by disassembling the switches to see if something was spilled inside it that shorted the circuitry.
Old Dec 31, 2019 | 06:11 AM
Avi Shuliman's Avatar
Ex37 gt
Hey
[QUOTE=05_SkylineSedan;7120323]But I'm still here. If you can't find the fuse yourself tell me the year and model of your G and I'll look it up for you.
Hey man i have a ex37 gt 2011.
same issue.
The drivers seat wont heat , the button is not shining.
Can you help me locate the fuse?
Old Dec 31, 2019 | 01:23 PM
20 Year Member
same issue.
Sorry, what does "ex37 gt" mean? Is it a 2011 g37x maybe? 4-doors or 2? Here's the FSM for the seats of a 2011 sedan:
https://www.nicoclub.com/FSM/G37/Sedan/2011/SE.pdf
For that sedan, fuses involved are #K, #3, #10, #35, #53, Thing is, I think a blown fuse would mean neither side would work. If your passenger side is working correctly then more likely something has failed on the driver's side only. That manual can help you trace the fault.
Old Dec 31, 2019 | 03:25 PM
  #30
cleric670's Avatar
BANNED!!!
He means 2011 Infiniti EX37
https://www.nicoclub.com/archives/in...e-manuals.html
Troubleshooting steps are in section SE - Seat
