heated seat is not working
Old May 7, 2014 | 05:03 PM
inked05's Avatar
Angry heated seat is not working
I have an 04 g35 x heated seat switch is not illuminating or the seat heat is not comeing on the seat either.i checked the fuse box but there is no lable for seat, please help ?
Old May 8, 2014 | 02:47 AM
05_SkylineSedan's Avatar
20 Year Member
Check the 10A fuse # 38 in the fuse / relay / fusible links box right in front of the battery. Here are some pics:
Attached Thumbnails heated seat is not working-pic1.jpg   heated seat is not working-pic2.jpg   heated seat is not working-pic3.jpg
Old May 8, 2014 | 05:34 AM
inked05's Avatar
Thank you for helping me 05 skyline👍
Old Oct 16, 2017 | 07:19 PM
IllaNoizeTV's Avatar
so what is the result? Did you get it fixed? My heated seats don't work either.
Old Oct 17, 2017 | 06:34 AM
Blue Dream's Avatar
I drove ttrank's car solo
He hasn't logged on in over 3 years so you probably won't get a response.
Old Oct 17, 2017 | 12:54 PM
20 Year Member
But I'm still here. If you can't find the fuse yourself tell me the year and model of your G and I'll look it up for you.
Old Oct 17, 2017 | 03:02 PM
I replaced the fuse with a brand new one and they still don't work. I checked the wires under both seats and everything is connected.
Old Oct 17, 2017 | 03:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Check the RELAY at the IPDM not just the fuse. Also do the lights on the switch illuminate when you turn them on? This is a basic and not-exact way to check there is actually voltage going to the switch.
Old Oct 17, 2017 | 03:12 PM
I apologize, electrical components are not my thing. The lights do not turn on either. Where is the relay located in the fuse box? And what is the relay called specifically?
Old Oct 17, 2017 | 04:05 PM
cleric670's Avatar
BANNED!!!
I've never physically looked up the relay and the description of the FSM says it's integrated with the IPDM (fuse box next to the battery). If the lights don't turn on then you aren't getting power to the switch which means start looking at the IPDM.
I recommend paying for a dealership diagnostic because I have a feeling your IPDM relay is cooked and is non-replaceable.
Old Oct 17, 2017 | 04:30 PM
Dang that sucks. Everything works on my car except the heated seats and the passenger side front and rear dome lights. I replaced the bulbs and nothing. Do you know what the dealership would even do if the ipdm is irreplaceable? Reprogram it?
Old Oct 17, 2017 | 05:22 PM
cleric670's Avatar
BANNED!!!
The relay inside the IPDM might be soldered on or something. Worst case is you need a new IPDM, HOWEVER, there's also a chance it's just the wiring going to the switch, still gotta probe for voltage at the switch, possibly the switch ground broke off, etc. Lots of troubleshooting left to determine the root cause of failure.
Old Oct 17, 2017 | 05:31 PM
Thank you for the encourage. Let's hope and pray it's something small. I'm gonna take it to a trusted shop that has a lot of experience on INFINITI's.
Old Oct 17, 2017 | 06:12 PM
Urbanengineer's Avatar
Could very well be on its way out. Anything else in that circuit having problems? (IE city lights, etc).
Old Oct 17, 2017 | 06:24 PM
Everything else works, lights, power seats, etc. I plan to take my car to the shop this week so I'll keep this thread updated when I find out.
